How to write to the clipboard using VBA?
T2ioTD
T2ioTD
I want to put a string in the clipboard, to ease the problematic writing to csv or Excel (for me it is a time consuming process, I prefer to send a string full of data via the clipboard, have Excel process it, and repeat this as many times as needed).
I have seen people using the DataObject, but Autocad is stating that this 'user-defined type not defined'.
I think I have to add a reference? But which one? Please help.
Dim myString As String: myString = "Hello, Clipboard"
Dim objectList As DataObject
objectList.SetText myString
objectList.PutInClipboard
seabrahenrique
Hello!
I have been using this function:
Function FA_Clipboard(Optional StoreText As String) As String
'PURPOSE: Read/Write to Clipboard
'Source: ExcelHero.com (Daniel Ferry)
Dim X As Variant
'Store as variant for 64-bit VBA support
  X = StoreText
'Create HTMLFile Object
  With CreateObject("htmlfile")
    With .parentWindow.clipboardData
      Select Case True
        Case Len(StoreText)
          'Write to the clipboard
            .setData "text", X
        Case Else
          'Read from the clipboard (no variable passed through)
            Clipboard = .GetData("text")
      End Select
    End With
  End With
  ThisDrawing.Utility.Prompt "'" & StoreText & "' copiado para ára de transferência!" & vbCrLf
End Function
Hope can help u
T2ioTD
Great, it works, but I had first to write:
Dim Clipboard
