Getstring with click options
seabrahenrique
seabrahenrique
Hello guys!
Currently i have some functions in my software that get some string by input user, and i use this way:
Op = ThisDrawing.Utility.GetString(False, "OP? [yes,no]")
So, my user can type Y for 'yes' or N for 'no' for example.
But i'd like to do something like that:
In this way, the usar can type but can also click on the option...
How can i do that?
Thanks in advance 🙂
Ed__Jobe
GetString is only for returning a string as input, like the a date or filename. For a command prompt, you use the GetKeyword function along with InitializeUserInput. Below is a sample of how to get and test the result. If you format your prompt string according to standard AutoCAD prompting, your keywords will automatically appear as links in the command line. Note the use of spaces, brackets and slashes.
Public Sub DeleteAllPSLayouts()
    'Deletes all paperspace layouts, leaving
    'a blank Layout1.
    'The model space tab cannot be deleted.
    Dim lyt As AcadLayout
    Dim Response As String
    Dim KeyWords As Variant
    KeyWords = "Yes No"
    ThisDrawing.Utility.InitializeUserInput 6, KeyWords
    Response = ThisDrawing.Utility.GetKeyword(vbCrLf & "Are you sure you want to delete all layouts? [Yes/No] :  Yes")
    If Response = "Yes" Or Response = "" Then
        For Each lyt In ThisDrawing.Layouts
            If lyt.ModelType = False Then
                lyt.Delete
        Next lyt
End Sub
Ed
How to post your code.
seabrahenrique
Perfect @Ed__Jobe!
I imagined it would be another function.
Thanks again!
