how to run a VBA macro Inside another vba macro ??
almutaz_86
Message 1 of 8
almutaz_86
Good Evening AutoCADian  people
I have some problems with vba, I'll try to explain it simply :
I draw boxes and rectangles in several measurements using  vba userform ,and I want to run another vba macro ( for draw circles on specific face(s) )- there is an attachment- some times on one face ,some times on 2 faces ....
how to run macros on right ,front or other sides of the box in vba ?
if it not possible, can I run a circles vba macro inside boxes vba macro  and make it together ?
thanks
Replies (7)
Message 2 of 8
almutaz_86
@Alfred.NESWADBA
If you may to see this please
Sorry for annoying
Smiley Very Happy
Message 3 of 8
Alfred.NESWADBA
>> of the box in vba ?
May I ask which part is the question?
  • how to run macros (as you are in a form)
  • create circles on some sides
In general, I guess it does not really make sense to draw circles on the surface of a 3D-object, what is the final goal with that? Creating bore oles?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 8
almutaz_86
Yes, exactly
Its for creating bores
There is a message in your inbox
Message 5 of 8
Alfred.NESWADBA
I have got your PM, this question is open:
- alfred -
Alfred NESWADBA
Message 6 of 8
almutaz_86
Good evening Mr @Alfred.NESWADBA
I'm sorry , I didn't read your question in your previous reply.
1-  I want to make a VBA macro {boring.dvb} to create circles from front,back,left or right view
 (independently for each side)
2-  Then active it in another macro {DividedCabinet.dvb} on Right side (for example).
center(0) =100: center(1) = 100 : center(2) =100
        length = 200: width =200: height =200
        Set box1 = ThisDrawing.ModelSpace.AddBox(center, length, width, height)
      ' then call (right side boring) macro to make bores on right side
center(0) =500: center(1) = 500: center(2) =500 length = 150: width =150: height =150 Set box2 = ThisDrawing.ModelSpace.AddBox(center, length, width, height) ' then call (front side boring) macro to make bores on front
sorry .. I'm weak in English, I hope that was clear   🙂
and thank you for your Help
Message 7 of 8
Alfred.NESWADBA
so when you started your code from "UserForm1" within "dividedcabinet" and you want to start a code from another module ("boring.dvb") you need to
  • define different names for the projects (yours are both named "ACADProject")
  • in the dividedcabinet you need to add a reference to the boring project (in VBAIDE menu Tools ==> References
  • declare a public sub or public function in the "boring.dvb" that can be called from the caller project
  • now you can call this sub or function
HTH, - alfred -
Alfred NESWADBA
Message 8 of 8
almutaz_86
Thank you for your efforts
Great explaining
I'm new in programming  I trying to learn it
Thanks again 👍🏻
