How to add data to table in autocad using vba
Dear Sir,
I am using table in autocad the for the adding the contents for BOM ....... and for the other data too..........
So i am planning to do perform a program to add the data using the prompt
Can you please give me some idea or code to add the data to row of the table using vba
thanks in advance
mallikarjun
Hallex
This will get you started I hope
{code}
Option Explicit
Sub Ch_Add_Table()
Dim minp As Variant
Dim maxp As Variant
Dim pt(2) As Double
Dim acTable As AcadTable
Set acTable = ThisDrawing.ActiveLayout.Block.AddTable(pt, 10, 4, 10, 60)
With acTable
.RegenerateTableSuppressed = True
.RecomputeTableBlock False
.TitleSuppressed = False
.HeaderSuppressed = False
.SetTextStyle AcRowType.acTitleRow, "ROMANS" '<-- change text style name here
.SetTextStyle AcRowType.acHeaderRow, "ROMANS"
.SetTextStyle AcRowType.acDataRow, "ROMANS"
Dim i As Double, j As Double
Dim col As New AcadAcCmColor
col.SetRGB 255, 0, 255
'title
.SetCellTextHeight i, j, 6.4
.SetCellAlignment i, j, acMiddleCenter
col.SetRGB 194, 212, 235
.SetCellBackgroundColor i, j, col
col.SetRGB 127, 0, 0
.SetCellContentColor i, j, col
.SetCellType i, j, acTextCell
.SetText 0, 0, "Table Title"
i = i + 1
'headers
For j = 0 To .Columns - 1
col.SetRGB 203, 220, 183
col.SetRGB 0, 0, 255
.SetCellTextHeight i, j, 5.2
.SetText i, j, "Header" & CStr(j + 1)
Next
'data rows
For i = 2 To .Rows - 1
.SetCellTextHeight i, j, 4.5
If i Mod 2 = 0 Then
col.SetRGB 239, 235, 195
Else
col.SetRGB 227, 227, 227
col.SetRGB 0, 76, 0
.SetText i, j, "Row" & CStr(i - 1) & " Column" & CStr(j + 1)
Next j
Next i
' set color for grid
col.SetRGB 0, 127, 255
.SetGridColor AcGridLineType.acHorzBottom, AcRowType.acTitleRow, col
.SetGridColor AcGridLineType.acHorzInside, AcRowType.acTitleRow, col
.SetGridColor AcGridLineType.acHorzTop, AcRowType.acTitleRow, col
.SetGridColor AcGridLineType.acVertInside, AcRowType.acTitleRow, col
.SetGridColor AcGridLineType.acVertLeft, AcRowType.acTitleRow, col
.SetGridColor AcGridLineType.acVertRight, AcRowType.acTitleRow, col
.SetGridColor AcGridLineType.acHorzBottom, AcRowType.acHeaderRow, col
.SetGridColor AcGridLineType.acHorzInside, AcRowType.acHeaderRow, col
.SetGridColor AcGridLineType.acHorzTop, AcRowType.acHeaderRow, col
.SetGridColor AcGridLineType.acVertInside, AcRowType.acHeaderRow, col
.SetGridColor AcGridLineType.acVertLeft, AcRowType.acHeaderRow, col
.SetGridColor AcGridLineType.acVertRight, AcRowType.acHeaderRow, col
.SetGridColor AcGridLineType.acHorzBottom, AcRowType.acDataRow, col
.SetGridColor AcGridLineType.acHorzInside, AcRowType.acDataRow, col
.SetGridColor AcGridLineType.acHorzTop, AcRowType.acDataRow, col
.SetGridColor AcGridLineType.acVertInside, AcRowType.acDataRow, col
.SetGridColor AcGridLineType.acVertLeft, AcRowType.acDataRow, col
.SetGridColor AcGridLineType.acVertRight, AcRowType.acDataRow, col
'set line weights for grid
.SetGridLineWeight AcGridLineType.acVertLeft, AcRowType.acTitleRow, AcLineWeight.acLnWt040
.SetGridLineWeight AcGridLineType.acVertRight, AcRowType.acTitleRow, AcLineWeight.acLnWt040
.SetGridLineWeight AcGridLineType.acHorzTop, AcRowType.acTitleRow, AcLineWeight.acLnWt040
.SetGridLineWeight AcGridLineType.acHorzBottom, AcRowType.acHeaderRow, AcLineWeight.acLnWt040
.SetGridLineWeight AcGridLineType.acHorzInside, AcRowType.acHeaderRow, AcLineWeight.acLnWt040
.SetGridLineWeight AcGridLineType.acHorzTop, AcRowType.acHeaderRow, AcLineWeight.acLnWt040
.SetGridLineWeight AcGridLineType.acVertInside, AcRowType.acHeaderRow, AcLineWeight.acLnWt040
.SetGridLineWeight AcGridLineType.acVertLeft, AcRowType.acHeaderRow, AcLineWeight.acLnWt040
.SetGridLineWeight AcGridLineType.acVertRight, AcRowType.acHeaderRow, AcLineWeight.acLnWt040
.SetGridLineWeight AcGridLineType.acHorzBottom, AcRowType.acDataRow, AcLineWeight.acLnWt040
.SetGridLineWeight AcGridLineType.acHorzInside, AcRowType.acDataRow, AcLineWeight.acLnWt040
.SetGridLineWeight AcGridLineType.acHorzTop, AcRowType.acDataRow, AcLineWeight.acLnWt040
.SetGridLineWeight AcGridLineType.acVertInside, AcRowType.acDataRow, AcLineWeight.acLnWt040
.SetGridLineWeight AcGridLineType.acVertLeft, AcRowType.acDataRow, AcLineWeight.acLnWt040
.SetGridLineWeight AcGridLineType.acVertRight, AcRowType.acDataRow, AcLineWeight.acLnWt040
.RegenerateTableSuppressed = False
.RecomputeTableBlock True
.Update
.GetBoundingBox minp, maxp
ZoomWindow minp, maxp
ZoomScaled 0.9, acZoomScaledRelative
ThisDrawing.SetVariable "LWDISPLAY", 1
Set col = Nothing
End With
MsgBox "Huh?"
End Sub
{code}
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
rmcefr
Hello
if we use the following statement to set specific Column Width only
.SetColumnWidth(col as integer,  Width as Double)
.SetColumnWidth(2, 100)
All Columns in Table will change, not only col No.2 !!!
Any idea How to Set Specific Column Width Only without change other columns
thanks
Ed__Jobe
First of all, this has nothing to do with this thread. You should have started a new thread.
.SetColumnWidth(2, 100) should work. Can you post your code and a sample dwg so we can see if there's something else going on?
Ed
How to post your code.
