Folder loop for dwg
04:04 AM
hi,
I am trying to create a block extractor using VBA. As for the extractor code, I believe it's finished, but I need to apply it to different files. As such, I need to create a loop in a folder.
I looked around and found this great piece of code for looping .xlsx, but I can't make it work for .dwg files.
Sub AllWorkbooks()
Dim MyFolder As String ‘Path collected from the folder picker dialog
Dim MyFile As String ‘Filename obtained by DIR function
Dim wbk As Workbook ‘Used to loop through each workbook
On Error Resume Next
Application.ScreenUpdating = False
‘Opens the folder picker dialog to allow user selection
With Application.FileDialog(msoFileDialogFolderPicker)
.Title = “Please select a folder”
.Show
.AllowMultiSelect = False
If .SelectedItems.Count = 0 Then ‘If no folder is selected, abort
MsgBox “You did not select a folder”
Exit Sub
MyFolder = .SelectedItems(1) & “\” ‘Assign selected folder to MyFolder
End With
myfile = Dir(MyFolder) ‘DIR gets the first file of the folder
‘Loop through all files in a folder until DIR cannot find anymore
Do While myfile <> “”
‘Opens the file and assigns to the wbk variable for future use
Set wbk = Workbooks.Open(Filename:=MyFolder & myfile)
‘Replace the line below with the statements you would want your macro to perform
Sheets(2).Range(“a1”).Value = 60
wbk.Close savechanges:=True
MyFile = Dir ‘DIR gets the next file in the folder
Loop
Application.ScreenUpdating = True
End SubThe code is very well explained by the creator, https://www.youtube.com/watch?v=J0PeXcAVaUM
Any help would be deeply appreciated 🙂
