Folder loop for dwg
Folder loop for dwg
Folder loop for dwg
hi,
I am trying to create a block extractor using VBA. As for the extractor code, I believe it's finished, but I need to apply it to different files. As such, I need to create a loop in a folder.
I looked around and found this great piece of code for looping .xlsx, but I can't make it work for .dwg files.
Sub AllWorkbooks()
   Dim MyFolder As String ‘Path collected from the folder picker dialog
   Dim MyFile As String ‘Filename obtained by DIR function
   Dim wbk As Workbook ‘Used to loop through each workbook
On Error Resume Next
Application.ScreenUpdating = False
‘Opens the folder picker dialog to allow user selection
With Application.FileDialog(msoFileDialogFolderPicker)
.Title = “Please select a folder”
.Show
.AllowMultiSelect = False
   If .SelectedItems.Count = 0 Then ‘If no folder is selected, abort
MsgBox “You did not select a folder”
      Exit Sub
   End If
MyFolder = .SelectedItems(1) & “\” ‘Assign selected folder to MyFolder
End With
myfile = Dir(MyFolder) ‘DIR gets the first file of the folder
‘Loop through all files in a folder until DIR cannot find anymore
Do While myfile <> “”
   ‘Opens the file and assigns to the wbk variable for future use
   Set wbk = Workbooks.Open(Filename:=MyFolder & myfile)
   ‘Replace the line below with the statements you would want your macro to perform
Sheets(2).Range(“a1”).Value = 60
wbk.Close savechanges:=True
MyFile = Dir ‘DIR gets the next file in the folder
Loop
Application.ScreenUpdating = True
End Sub
The code is very well explained by the creator, https://www.youtube.com/watch?v=J0PeXcAVaUM
Any help would be deeply appreciated 🙂
norman.yuan
You did not explicitly say, but I assume your "block extractor" run in AutoCAD VBA. The code you found/showed here is for Excel VBA, so, you need to make some changes on two things:
1. In AutoCAD VBA, there is NO BUILT-IN function to call up a "Folder Picker" dialog box for user to select a folder. You need to use WINDOW API's Folder Browser to 64-bit, which had been discussed in this forum a few times before.
2. The code of using Dir() to loop through a folder needs minor change. But, unlike the code you showed here, I strongly recommend you use Dir() to obtain a list of file names, instead of do anything to each file within each loop (such as in the code where in each loop, a sheet was updated and then closed; then going to another sheet file...). So the code would be like:
Function GetDwgFiles(folderPath As String) As Variant
  Din i As Integer
  Dim files() As String
  Dim fName As string
  fName=Dir(folderPath & "\*.dwg")
  Do While (fName<>"")
    ReDim Preserve files(i)
    files(i)=fName
    i = i + 1
    fName = Dir
  Loop
  GetDwgFiles = files
End Function
Then in block extractor code, you do
Dim folder As String
'' you need to find something to let user to pick the folder, as aforementioned
'' you can search the net for "folder browser 64-bit". Warning, it is not an easy
'' thing, if you are not experienced programmer
folder = "....."
Dim files As Variant
files = GetDwgFiles(folder)
Dim i As Interger
Dim dwgFile
For i = 0 To Ubound(files)
    dwgFile = files(i)
    //Do the block extracting work with this drawing file
Next
Norman Yuan
Drive CAD With Code
Although the users have AutoCAD knowledge, I intend to launch the macro from excel, with a click of a button.
Since your tips were for AutoCAD VBA, what do you recommend for Excel VBA?
thanks in advance
norman.yuan
If you actually run Excel VBA, the my code would be the same, except for
folder =  "...."
Can be easily changed to
folder=GetFolder()
If Len(folder)=0 Then
  Exit sub
End If
'' Now get file list in the folder
'' Then process each file in the file list/array
Function GetFolder() As string
  With Application.FileDialog (msoFileDialogFolderPicker)
   '' Same code as in your original post
  End With
  GetFolder = MyFolder
End Function
Norman Yuan
Drive CAD With Code
Thanks, will give it a try tomorrow 🙂
