Hallo,
thanks for your answer.
But what is VLAX? Is it a vba-command (no) or a method?
Have you a little sample for me, so I can see the function.
Thanks for your help.
Hartmut Callies
callies@web.de
__________________________________________________________________
"Frank Oquendo" schrieb im Newsbeitrag
news:086C0E816355DAC204F64FBA7D39DCCC@in.WebX.maYIadrTaRb...
> That would be a little tricky due to the various property names associated
> with entity coordinates (StartPoint, EndPoint, Coordinates, etc.). In VBA,
> you'd have a rather large Select Case structure.
> One possibility would be to use VLAX to retrieve all the group code 10s
and
> 11s present in an object entity definition data.
> http://www.acadx.com
> "That's no ordinary rabbit."
> "Hartmut Callies" wrote in message
> news:5D6655C44C81791E479A484AF3998876@in.WebX.maYIadrTaRb...
> > Hallo,
> > how can I extract the x,y,z-coordinate from all objects in the drawing?
> > Must I select the objects (all lines, all polylines, ...) and can I then
> > extract
> > the coordinate?
> > Thanks
> > Hartmut Callies
