Excel VBA - run overkill command on selection set
cool.stuff
Message 1 of 22
cool.stuff
Hi!!
i'm trying to run overkill command on a selection set. This is my current code:
*Moderator Edit* changed code language to VB
        'select all objects of layer "GapPoints"
        Dim tSelSet As AcadSelectionSet
        Dim FromLayer As String
        FromLayer = "GapPoints"
        Dim pSelSetName As String
        pSelSetName = "mySelSetGapPoints"
        'create SelectionSet
        On Error Resume Next
        Set tSelSet = acadDoc.SelectionSets.Item(pSelSetName)
        If (Not (tSelSet Is Nothing)) Then
            tSelSet.Clear
        Else
            Err.Clear
            Set tSelSet = acadDoc.SelectionSets.Add(pSelSetName)
        'create selection filter
        'Filtering SelectionSet
        Dim tDxfCodes(0) As Integer
        Dim tDxfValues(0) As Variant
        tDxfCodes(0) = 8
        tDxfValues(0) = FromLayer
        'create selection
        Call tSelSet.Select(acSelectionSetAll, , , tDxfCodes, tDxfValues)
        Dim acadcommand As String
        'acadcommand = """" & "_-overkill" & """" & ", tSelSet, " & """" & """" & ", " & """" & """"
        acadcommand = "_-overkill" & vbCr & "tSelSet" & vbCr & vbCr
        ' run overkill command on created selection set previously
        acadApp.ActiveDocument.SendCommand acadcommand & vbCr
Both lines 32 and 33 give error.
Does anybody knows to to run overkill command on a selection set via Excel VBA please?
Many thanks! 🙂
Replies (21)
Message 21 of 22
Ed__Jobe
It has to do with "scope" You declare tSelSet on line 12, but when you move to RunOverkillOnSelectionset, the tSelSet variable goes out of scope, i.e. it becomes Nothing. By passing only a string to the function, you only get a new ss with the same name. Therefore I changed the signature of RunOverkillOnSelectionset to pass an AcadSelectionSet object. That way the variable doesn't go out of scope. It gets passed by reference to the new function.
Ed
How to post your code.
Message 22 of 22
cool.stuff
Many thanks @Ed__Jobe  🙂 quite useful (sorry for the late answer!)
Best regards
