Erase source objects -promt
I just moved from using AutoCAD LT 2018 to using AutoCAD 2019
I’m trying to make everything work the way I’m used.
In 2018 LT when using mirror the “Erase source objects?”-promt is shown right next to the cursor with "yes" or "no".
In AC2019 similar prompt won’t show up. How to change it?
Ed__Jobe
You need to adjust your Dynamic Input settings. Right click on the DYNMODE icon to get a button for the Dynamic Input Settings dialog. If you don't see the icon shown, you need to turn it on by clicking on the  3 bars in the lower right corner and checking the dynamic input option.
BTW, the AutoCAD forum is over here.
Ed
How to post your code.
Perfect! Thank you.
