Custom Drawing Properties Userform
Message 1 of 11
I'm looking at creating a custom Drawing Properties form, similar to the "DWGPROPS" command. To allow our Titleblocks to be automatically filled.
We currently use "DWGPROPS" as it stands with fields to put in the relevant information but I'd like all the information to be filled out on one tab.
I've almost got the form done how I'd like it laid out but I was wondering if anyone could give any pointers with regards to coding it so works the same as "DWGPROPS"
I have tried to find to code for the current form with no luck and can't seem to find anything online (I have googled) with regards as to to how the 'OK' event handler should work but like I said I am a complete beginner.
Thanks in advance for any help you can give me.
Replies (10)
Message 2 of 11
norman.yuan
I assume you are using 64-bit AutoCAD and 2014 or later (thus 64-bit VBA). The reason I metion this is because 64-bit VBA has very limited UI component support. When you want to have a good UI to control what user can input data for the custom properties, you may want to have best UI experience built with your progarm. For example, if you want a property value to be a valid Date/Time value, you may want to use a DateTimePicker control, which is not available for 64-bit VBA (well, at leat is not easily/directly available in AutiCAD VBA).
With taht said, and if you only need to know/learn how to trigger a UI for getting user input, here is code samples (and video clip showing how the code works):
First, a class module: clsDwgProp
Option Explicit
Public propName As String
Public propValue As String
Then, a class module: clsDwgProps
Option Explicit
Public DwgProperties As Collection
Public Property Get CustomPropertyCount() As Integer
    CustomPropertyCount = DwgProperties.Count()
End Property
Public Sub GetDwgProperties(dwg As AcadDocument)
    Dim i As Long
    Dim prop As clsDwgProp
    Dim key As String
    Dim val As String
    For i = 0 To dwg.SummaryInfo.NumCustomInfo() - 1
        dwg.SummaryInfo.GetCustomByIndex i, key, val
        Set prop = New clsDwgProp
        prop.propName = key
        prop.propValue = val
        DwgProperties.Add prop, prop.propName
    Next
End Sub
Public Function SetProperty(propName As String, propValue As String) As Boolean
    Dim found As Boolean
    If IsValidValue(propName, propValue) Then
        For Each prop In DwgProperties
            If UCase(prop.propName) = UCase(propName) Then
                found = True
                prop.propValue = propValue
                Exit For
        Next
        If Not found Then
            prop.propName = propName
        SetProperty = True
    Else
        SetProperty = False
End Function
Public Sub SaveDwgProperties(dwg As AcadDocument)
    Dim i As Integer
    Dim key As String
    Dim val As String
        found = False
        For i = 0 To dwg.SummaryInfo.NumCustomInfo - 1
            If UCase(key) = UCase(prop.propName) Then
                dwg.SummaryInfo.SetCustomByKey prop.propName, prop.propValue
                found = True
                Exit For
        Next
        If Not found Then
            dwg.SummaryInfo.AddCustomInfo prop.propName, prop.propValue
    Next
End Sub
Private Function IsValidValue(propName As String, propVal As String) As Boolean
    '' Do property value validation here
    IsValidValue = True
End Function
Private Sub Class_Initialize()
    Set DwgProperties = New Collection
End Sub
As you can see these 2 classes are resposible to retrieve/add/update drawing custom properties (for simplicity, I omiited deleting property...)
Then I used a form to show existing properties, where user can update property values, and add new property. Again, for simplicity, I only show the first 2 properties; and only allows to add one property at a time; and do not presnt a way to delete properties. Also, because of the 64-bit VBA UI limitation, I useed simple lable and textbox. It would better to use a DataGridView, as the AutoCAD built-in UI (with command "DWGPROPS"). But the for would be enough to show the workflow: how to get user input, what to do if user click "OK", or "Cancel"...
Here is the code for the UserForm (you can see how the form looks in the video):
Option Explicit
Private mOked As Boolean
Private mProps As clsDwgProps
Public Property Get isOked() As Boolean
    isOked = mOked
End Property
Public Sub SetForm(props As clsDwgProps)
    Set mProps = props
    Dim i As Integer
    Dim lbl As Label
    Dim txt As TextBox
    For Each prop In mProps.DwgProperties
        i = i + 1
        If i > 2 Then Exit Sub '' For the sake of simplicity, only show 2 properties
        Set lbl = GetLabel(i)
        Set txt = GetTextBox(i)
        lbl.Caption = prop.propName
        txt.Value = prop.propValue
    Next
End Sub
Private Function GetLabel(index As Integer) As Label
    Dim name As String
    name = "lbl" & index
    Set GetLabel = FindControl(name)
End Function
Private Function GetTextBox(index As Integer) As TextBox
    Dim name As String
    name = "txt" & index
    Set GetTextBox = FindControl(name)
End Function
Private Function FindControl(name As String) As Control
    Dim ctl As Control
    Dim foundCtl As Control
    Set foundCtl = Nothing
    For Each ctl In Me.frameEdit.Controls
     If ctl.name = name Then
        Set foundCtl = ctl
        Exit For
    Next
    Set FindControl = ctl
End Function
Private Function GetUserInputs() As Boolean
    Dim i As Integer
    Dim propName As String
    Dim propValue As String
    Dim lbl As Label
    Dim txt As TextBox
    For i = 1 To 2
        propName = lbl.Caption
        propValue = txt.Value
        If Not mProps.SetProperty(propName, propValue) Then
            GetUserInputs = False
            Exit Function
    Next
    If Trim(txtName.Value) <> "" And Trim(txtValue.Value) <> "" Then
        If Not mProps.SetProperty(Trim(txtName.Value), Trim(txtValue)) Then
            Exit Function
    GetUserInputs = True
End Function
Private Sub cmdCancel_Click()
    mOked = False
    Me.hide
End Sub
Private Sub cmdOK_Click()
    If Not GetUserInputs() Then
        Exit Sub
    mOked = True
    Me.hide
End Sub
Finally, here is the macro module that actually run the program:
Option Explicit
Public Sub DoDwgPropers()
    Dim props As clsDwgProps
Set props = New clsDwgProps
props.GetDwgProperties ThisDrawing
MsgBox props.CustomPropertyCount & " custom properties found!"
Dim dlg As dlgProps
Set dlg = New dlgProps
Dim isOked As Boolean
dlg.SetForm props
dlg.show
isOked = dlg.isOked
Unload dlg
If isOked Then
props.SaveDwgProperties ThisDrawing
End Sub
HTH.
Norman Yuan
Drive CAD With Code
Message 3 of 11
rbh1
Can you post the actual project here, I'm having a hard time trying to use the code posted?
Message 4 of 11
Ed__Jobe
Did you paste all the code to the same module? or did you create the specified class modules and put in their respective code?
Ed
How to post your code.
Message 5 of 11
rbh1
Thank you,
I posted all the code to the same module, I see now they are different modules.  Duh Thank you.
Message 6 of 11
Ed__Jobe
The code goes in 4 different modules. Note the instructions just above each code window. The first two are class modules, the 3rd goes in the form's code module and the last goes in a standard module.
Ed
Message 7 of 11
rbh1
I'm still having some issues,  I think it may just be my lack of knowledge on how this should be setup.
Message 8 of 11
Ed__Jobe
When you created the two class modules, did you right click on the Modules node, select Insert>Class Module? There are two types of modules, regular modules and class modules, which can be instantiated.
Create Class ModuleCreate Class Module
Ed
Message 9 of 11
rbh1
yes i did attached is a screen shot of what i did.
Message 10 of 11
Ed__Jobe
Please state what your issues are. Did you create a form or just paste the code?
Ed
Message 11 of 11
rbh1
I pasted in the code. let me take another look at this.    The error message I'm getting is a Compile error: User-defined type not defined
Public Sub DoDwgPropers()   is highlighted
  1. I need to make a userform matching yours?
I think that may be my first issue.
