Capturing multiple range in Excel from AutoCAD VBA
06:35 AM
I have a project I am working on which in AutoCAD VBA which needs to read in
the information contained in a multiple range. The following is my code:
Set ExcelApp = GetObject(, "Excel.Application")
If Err Then
Err.Clear
Set ExcelApp = CreateObject("Excel.Application")
If Err Then
MsgBox Err.Description, vbCritical, "Warning"
Exit Function
On Error GoTo 0
Set ExcelWorkbook = ExcelApp.Workbooks.Open(Temp)
Set ExcelWorkbook = ExcelApp.ActiveWorkbook
rangeArray = ExcelWorkbook.worksheets("Output").Range("F37:F60")
ExcelApp.Application.Quit
The above code works fine capturing the values of the range F37:F60. I need
the range F37:F60 plus the cells F10 and B3 in the same array. I can create
a named range in the spreadsheet called Range1 that is defined as
=Output!$F$37:$F$60,!Output$F$10,!Output$B$3. I have attempted the
following code based on examples in the Excel VBA help file, but neither of
them work:
rangeArray = ExcelWorkbook.worksheets("Output").Range("F37:F60,F10,B3")
rangeArray = ExcelWorkbook.worksheets("Output").Range("Range1") 'Range1
defined as above
Each of the above lines only returns the range F37:F60.
Any help or suggestions at all would be very much appreciated. TIA
Michael Teague
CADD Support Technician
Matrix Service, Inc.
If Err Then
Err.Clear
If Err Then
Exit Function
On Error GoTo 0
them work:
defined as above
Michael Teague
