Capturing multiple range in Excel from AutoCAD VBA
I have a project I am working on which in AutoCAD VBA which needs to read in
the information contained in a multiple range. The following is my code:
Set ExcelApp = GetObject(, "Excel.Application")
If Err Then
Err.Clear
Set ExcelApp = CreateObject("Excel.Application")
If Err Then
MsgBox Err.Description, vbCritical, "Warning"
Exit Function
End If
End If
On Error GoTo 0
Set ExcelWorkbook = ExcelApp.Workbooks.Open(Temp)
Set ExcelWorkbook = ExcelApp.ActiveWorkbook
rangeArray = ExcelWorkbook.worksheets("Output").Range("F37:F60")
ExcelApp.Application.Quit
The above code works fine capturing the values of the range F37:F60. I need
the range F37:F60 plus the cells F10 and B3 in the same array. I can create
a named range in the spreadsheet called Range1 that is defined as
=Output!$F$37:$F$60,!Output$F$10,!Output$B$3. I have attempted the
following code based on examples in the Excel VBA help file, but neither of
them work:
rangeArray = ExcelWorkbook.worksheets("Output").Range("F37:F60,F10,B3")
rangeArray = ExcelWorkbook.worksheets("Output").Range("Range1") 'Range1
defined as above
Each of the above lines only returns the range F37:F60.
Any help or suggestions at all would be very much appreciated. TIA
Michael Teague
CADD Support Technician
Matrix Service, Inc.
Hi! Michael,
I dont know why it doesn't work in your case.
I have the following code which essentially does the same thing and it works
fine in A2K.
Could remove "On Error go to 0 and check what trap the error(if at all error
is generated)?
'______________________________
Sub f_selectRange()
Dim po_xl As Application
Dim po_ws As Worksheet
Dim po_rg As Range
'keep the excel open to run this
Set po_xl = GetObject(, "Excel.Application")
'select multiple cells
Set po_ws = po_xl.Worksheets("Sheet2")
po_ws.Activate
Set po_rg = po_ws.Range("A1:A10,F1:F3,B10")
po_rg.Select
End Sub
bye,
P.Murali
Michael Teague wrote in message
news:[email protected]...
in
> Michael Teague
