VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Add Material/ Texture For Object by VBA
1 REPLY 1
1341 Views, 1 Reply
Hi.
I try to figure out the VBA's code to apply material for each part object in my this drawing.
Of course, I can do it manually, but I would like to run a code to apply multiple file to save time.
Can anyone help me code VBA for it? Thanks.
1 REPLY 1
norman.yuan
All AutoCAD entity object (AcadLine, AcadSolid, AcadSurface, AcadCircle, or more generic AcadEntity) as a string property "Material". So, to set a material to an AcadEntity, simply set this property to a valid AcadMaterial's name. Sample code:
Option Explicit
Public Sub test()
    Dim mat As AcadMaterial
    Dim matName As String
    For Each mat In ThisDrawing.Materials
        ''MsgBox mat.Name
        If UCase(mat.Name) = "SITEWORK.PLANTING.GRASS.SHORT" Then
            matName = mat.Name
            Exit For
    Next
    If Len(matName) > 0 Then
        Dim ent As AcadEntity
        For Each ent In ThisDrawing.ModelSpace
            If TypeOf ent Is AcadSolid Then
                ent.Material = matName
        Next
End Sub
Norman Yuan
Drive CAD With Code
AutoCAD Inside the Factory
