A program to draw boreholes (CPT) logs from Excel file in AutoCAD!?
giscivil92
Message 1 of 8
giscivil92
Hi everyone
I am looking for a program Lisp or VBA to draw boreholes (CPT) logs from Excel file in AutoCAD!?
Thank you in advance for helping me.
Replies (7)
Message 2 of 8
Ed__Jobe
That's a pretty specific request. I've never seen anyone doing such work. Most likely, you're going to have to do it yourself I'm afraid.
Ed
How to post your code.
Message 3 of 8
giscivil92
@Ed__Jobe Hi
Yes, you are right.
Actually, I asked it because I thought there was a program or something like this to do it.
Message 4 of 8
norman.yuan
If you do it, I suggest you do it with .NET API rather than VBA. A bit of unfortunate, Acad2025's .NET API just transit from .NET Framework to .NET 8, which is a compatibility-break change, you would have issue of supporting pre-Acad2025 versions and/or Acad2025. Still doing it with .NET API would be better option on the long run for this type of programming effort.
If you really can do it with minimum UI (because of 64-VBA's limitation), do it inside AutoCAD VBA, rather than do it from Excel VBA via COM automation.
Norman Yuan
Drive CAD With Code
Message 5 of 8
Ed__Jobe
I agree with @norman.yuan  The bulk of the work is with AutoCAD entities. You only need to read some input from Excel from within acad. And you can do that in NET or VBA.
Ed
Message 6 of 8
giscivil92
Thanks for your attention @Ed__Jobe @norman.yuan
Actually, my problem is I don't know VBA otherwise I created a program to do it.
Message 7 of 8
Ed__Jobe
That's the reason why we learned how to program, so we could solve our own problems and be better, more efficient. Although, we help out with samples and fixing other's code, it often takes too much time to do something from scratch. There are programmers that hire themselves out. But you need to be able to fully describe what you want your app to do and how it should be done.
Ed
Message 8 of 8
norman.yuan
If you are looking for "read-to-use" program, this is probably not the place for that. If you have a similar program with source code, and you are able to or try to modify/update certain lines of them, you can ask in this forum.
If you do not program, then, you either find existing program that does the exactly what you want (it is almost impossible), or take whatever the existing program does. Or, very likely, if enhance the productivity is mission-critical to your business for that kind of drafting work, it is worth to hire a capable programmer does it for you (well, it is also quite hard to find really good CAD programmer!). I'd say a task as you wanted would take at least a couple of weeks, or a full month, or long to be fully developed, which would cost you a few thousands to start with. But consider the productivity enhancement - manual drafting for a full day, or two, becomes a few seconds (maybe a couple of minutes, say the user has to select and open the correct data sheet and click the "Go" button").
Norman Yuan
Drive CAD With Code
