zoom in other Acaddocument
MakCADD
MakCADD
hello,
need your help
i want to use zoom command in another drawing which is opened in same autocad window using vba while working in thisdrawing
norman.yuan
When you say "zoom command", it could mean 2 things: calling the built-in command "Zoom" with SendCommand() method, or calling AcadApplication.Zoomxxxx() method in your code.  Both only are applicable to active document, of course.
By essence, "Zoom in/out" (or "Pan", for that matter) is the visual effect of setting the current AcadViewport to a different AcadView. So, you can create an AcadView with desired target/width/height and set the view to the active viewport of the said document.
Norman Yuan
Drive CAD With Code
