Extracting Information From Blocks
felix.cortes5K3Y2
Message 1 of 10
felix.cortes5K3Y2
Hi Forum,
I have a block used several times on an Autocad sheet and I want to get each instance as well as all of its attributes. The name of the block is called "MASS INTERMEDIATE DYNAMIC". I can't seem to get the count of the amount of instances used on the drawing and get the attributes. The code below only returns one instance of the block but I know it's used 20 times on my autocad sheet.
Dim acad1 As AcadApplication
acad1 = Marshal.GetActiveObject("Autocad.Application")
Dim oDoc As AcadDocument = acad1.ActiveDocument
Dim oblocks As AcadBlocks = oDoc.Blocks
Dim sblock As String = "MASS INTERMEDIATE DYNAMIC"
Dim blockname As String
For Each oblock As AcadBlock In oblocks
    blockname = oblock.Name
    If Not InStr(1, blockname, sblock) > 0 Then Continue For
    Debug.Print(blockname)
Next
Felix
Replies (9)
Message 2 of 10
MakCADD
if it is dynamic block then the name is
block.effectivename  not block.name
Message 3 of 10
felix.cortes5K3Y2
Thanks for the response... that doesn't really help me with this question
Message 4 of 10
MakCADD
your document contains only one block definition in blocks collections
instances are blockreferences inserted in the drawing
you declared variable as block  you may be asking about block not about blockreference.....
Message 5 of 10
felix.cortes5K3Y2
I see, so I should be using AcadBlockReference then. How do I retrieve all of the block references of a document?
I'm trying to re-write the For-Next loop to this:
For Each oblockref As AcadBlockReference in oDoc.Blocks
    blockname = oblockref.Name
Next
I seem to get an error because I am not getting the collection of the block references correctly.
Felix
Message 6 of 10
MakCADD
Loop through all objects,. Find the entityname AcDbBlockreference, set the object,. Then verify the block reference name or effective name if it is dynamic block.
But I think u are not using VBA.  It look like something else
Message 7 of 10
seabrahenrique
Hey mate!
If i understand correctly, a Selection Set can help u in this case!
Try this code to interact with each block reference in your drawing:
Function FA_SST(nomeT As String) As AcadSelectionSet 'Create a Selection Set for a especific type
Dim filterType(0) As Integer, filterData(0) As Variant
Set FA_SST = ThisDrawing.SelectionSets.ADD("SS01")
filterType(0) = 0: filterData(0) = nomeT
FA_SST.Select acSelectionSetAll, , , filterType, filterData
End Function
Sub ForEachBlock()
Dim SS As AcadSelectionSet, Obj As AcadEntity
Set SS = FA_SST("INSERT")
For Each Obj In SS
    Debug.Print Obj.EffectiveName
Next Obj
End Sub
Glad to help
Message 8 of 10
felix.cortes5K3Y2
Hey thanks for the response! Is it possible to just get all of the references of the Autocad sheet? I don't really need a selection set. Just need to retrieve the instances that block is used on the autocad sheet and its attributes.
Felix
Message 9 of 10
norman.yuan
Assuming by saying "AutoCAD sheet", you mean Layout/PaperSpace. If using AcadSelectionSet, you can add layout name filter to select block reference on given layout. But looping through Layout block would be more straightforward/simple enough (assume you want to go through all layouts for block reference with given name):
Dim ent As AcadEntity
Dim lay As AcadLayout
Dim blk As AcadReference
For Each lay in ThisDrawing.Layouts
  For Each ent in lay.Block
    If TypeOf ent Is acadBlockreference Then
      Set blk=ent
      If UCase(blk.EffectiveName)="MY_TARGET_BLOCK" Then
         MsgBox "This is the block I am looking for on Layout """ & lay.Name & """".
         GetDataFromBlockAttributes blk
  Next
Next
Private Sub GetDataFromBlockAttributes(blk As AcadBlockReference)
   Dim atts As Variant
   Dim att As AcadAttributereference
   Dim i As Integer
   Dim attValue As String
   atts = blk.GetAttributes()
   For i=0 to UBound(atts)
      Set att=atts(i)
      Select Case UCase(att.TagString)
         Case "TAG1"
            attValue=att.TextString
            '' Do whatever with the attribute value...
         Case "TAG2"
     End Select
   Next
End Sub
HTH
Norman Yuan
Drive CAD With Code
Message 10 of 10
felix.cortes5K3Y2
Sweet! This helped a ton. Thank you for your help.
