zoom extents all layouts with vba
I want to make a code to zoom extents all layouts in a open drawing.
I wrote this but it doesn't work at all:
Sub zoomextentslayouts()
Dim Laytab As AcadLayout
For Each Laytab In ThisDrawing.Layouts
ZoomExtents
Next Laytab
End Sub
I'm sure somebody can help me Smiley Happy
thanx!
Laszlo
Alfred.NESWADBA
Zoom-Extents works for the current view. And within your loop you never made a layout active 😉
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
But how can I make the layouts active? (I do not want the names of the layouts in my code).
gr. Laszlo
Alfred.NESWADBA
e.g. set the CTAB-variable
      Call ThisDrawing.SetVariable("CTAB", Laytab.Name)
      'make sure paperspace is active (and not modelspace in an mview-object)
      If Laytab.Name <> "Model" Then
         If ThisDrawing.MSpace Then ThisDrawing.MSpace = False
      ZoomExtents
   Next Laytab
End Sub
HTH, - alfred -
Alfred NESWADBA
Danke schön Alfred!
It works great!
gr. Laszlo
fxcastil
This example uses the "ActiveLayout" property instaed of the system variable "CTAB"
Sub ZoomExtentsLayouts()
Dim LayTab As AcadLayout
For Each LayTab In ThisDrawing.Layouts
  ' this uses the "ActiveLayout" property of the the layouts
   ThisDrawing.ActiveLayout = LayTab
   ' this uses the system variable "CTAB" to select the next layout
   'Call ThisDrawing.SetVariable("CTAB", Laytab.Name)
   ' make sure PaperSpace is active and not modelspace in each layout
  ' this is shown on the Paper/Model space tab in each layout
     If LayTab.Name <> "Model" Then
    ZoomExtents
   Next LayTab
End Sub
