Layer + linetype
Layer + linetype
Layer + linetype
How to create new layer and with linet type?
How to write code ?
shan
Alfred.NESWADBA
may I introduce you to the VBA (for AutoCAD) -HELP 😉
you find there all objects and all methods/properties and for (nearly) all methods you have examples to take.
Look how I would solve your questions using the help within the video.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Hallex
Found in my oldies
Option Explicit
' Function to determine if a layer exists
' **** Kusleika's method
Public Function LayerExists(lyrName As String) As Boolean
     Dim oLayer As AcadLayer
     On Error Resume Next
     Set oLayer = ThisDrawing.Layers(lyrName)
     LayerExists = (Err.Number = 0)
End Function
' Function to determine if a linetype exists
Public Function LineTypeExists(ltpName As String) As Boolean
     Dim oLineType As AcadLineType
     Set oLineType = ThisDrawing.Linetypes(ltpName)
     LineTypeExists = (Err.Number = 0)
End Function
' Function to set an existing layer or create a new drawing layer
 Function AddLayer(layerName As String, ltpName As String, intColor As Long, intLweight As Integer, strDesc As String, Optional blnPlot = True) As AcadLayer
With ThisDrawing
 Dim strVer As String
 strVer = "AutoCAD.AcCmColor." + Left(CStr(.GetVariable("ACADVER")), 2)
 Dim acmColor As AcadAcCmColor
 Set acmColor = AcadApplication.GetInterfaceObject(strVer)
 acmColor.ColorIndex = intColor
 ' Add the layer to the layers collection
 Set oLayer = .Layers.Add(layerName)
 If Not LineTypeExists(ltpName) Then
 If .GetVariable("MEASUREINIT") = 0 Then
 .Linetypes.Load ltpName, "acad.lin"
 Else
 .Linetypes.Load ltpName, "acadiso.lin"
oLayer.Linetype = ltpName
oLayer.Lineweight = intLweight
oLayer.TrueColor = acmColor
' Put plottable if does not defined in the calling function
If Not blnPlot Then
oLayer.Plottable = Not oLayer.Plottable
oLayer.Plottable = blnPlot
' Put description
oLayer.Description = strDesc
' Make the new layer the active layer for the drawing
.ActiveLayer = oLayer
End With
Set acmColor = Nothing
Set AddLayer = oLayer
End Function
Sub bb()
Call AddLayer("ALAYER", "DASHDOT2", 162, 60, "My description")
End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
