xref list
xref list
Message 1 of 11
xref list
using autocad 14 and vba how would i get a list of xrefs in the current
drawing?
Rob
Replies (10)
Message 2 of 11
I''m new to VBA so excuse me for all the bad programming in this routine.
I'm trying to get it to tell me what xref's and nested xref's are in a
drawing and give their file path, insertion point and scale.
I can get this information for the main xref's but I can only seem to get
the name for the nested xrefs.
I cant seem to get my head round the difference between a block and a
blockreference and why I can can only get certain properties for each one.
Graeme
Option Explicit
Public Sub QDA_list()
On Error Resume Next
Dim XrfObj As AcadBlock
Dim XrfRef As AcadBlockReference
Dim Xrfnme As String
Dim XrfInsPt As Variant
Dim XrfScle As Variant
Dim XrfPath As String
Dim i As Integer
Dim Count As Integer
For i = 0 To Count + 1
For Each XrfObj In ThisDrawing.Blocks
Set XrfRef = XrfObj.Item(i)
If XrfObj.IsXRef Then
Xrfnme = XrfObj.Name
'If Xrfnme = "" Then
'MsgBox "there are no xrefs in this drawing"
XrfInsPt = XrfRef.InsertionPoint
XrfScle = XrfRef.XScaleFactor
XrfPath = XrfRef.Path
MsgBox "The xrefs attached include " & Xrfnme
MsgBox "The xref path is " & XrfPath
MsgBox "The xref scale is " & XrfScle
MsgBox "The xrefs are at " & XrfInsPt(0) & ", " & XrfInsPt(1) &
", " & XrfInsPt(2)
End If
Next
Next i
End Sub
Message 3 of 11
The problem is this huge hole in the object model that exposes the path of
an XRef *only* via AcadExternalReference instead of thru the Block object.
Give this a shot:
Option Explicit
Public Sub Test()
Dim XRefs As New Collection
Set XRefs = GetXRefs
Dim XRef As AcadExternalReference
Dim ynInserted As Boolean
Dim i As Integer
For i = 1 To XRefs.Count
Set XRef = XRefs(i)
ynInserted = IsInserted(XRef)
Debug.Print _
"XRef name: " & XRef.Name & _
vbCrLf & "XRef path: " & XRef.Path
If ynInserted Then
Debug.Print _
"Inserted at: " & _
CStr(XRef.InsertionPoint(0)) & "," & _
CStr(XRef.InsertionPoint(1)) & "," & _
CStr(XRef.InsertionPoint(2)) & _
vbCrLf & "Scale factor: " & XRef.XScaleFactor
End If
Next i
End Sub
Private Function IsInserted(Block As AcadExternalReference) As Boolean
Dim BlockOwner As Long
BlockOwner = Block.OwnerID
If BlockOwner = ThisDrawing.ModelSpace.ObjectID Then
IsInserted = True
Exit Function
End If
Dim ThisLayout As AcadLayout
For Each ThisLayout In ThisDrawing.Layouts
If BlockOwner = ThisLayout.ObjectID Then
IsInserted = True
Exit Function
End If
Next ThisLayout
End Function
Private Function GetXRefs() As Collection
Dim ThisBlock As AcadBlock
Dim ThisObject As AcadEntity
Dim AnXRef As AcadExternalReference
Dim Result As New Collection
Dim i As Integer
For Each ThisBlock In ThisDrawing.Blocks
For Each ThisObject In ThisBlock
If TypeOf ThisObject Is AcadExternalReference Then
Set AnXRef = ThisObject
Result.Add AnXRef, CStr(i)
i = i + 1
End If
Next ThisObject
Next ThisBlock
Set GetXRefs = Result
Set Result = Nothing
End Function
R. Robert Bell, MCSE
www.AcadX.com
"Graeme Hyslop" wrote in message
news:[email protected]...
| Thanks
| Graeme
| Option Explicit
| Dim i As Integer
| ", " & XrfInsPt(2)
| End If
| Next
| Next i
| End Sub
Message 4 of 11
Thank you Robert that worked almost perfect. To start with it listed the
name and path of them all, but only the scale and insertion point of the
first xref. By commenting out the If ynInserted ... line it worked
perfectly. Is the If ynInserted ... line important for something ?
Graeme
> Option Explicit
> Public Sub Test()
> Dim i As Integer
> Set XRef = XRefs(i)
> Debug.Print _
> If ynInserted Then
> Debug.Print _
> "Inserted at: " & _
> End If
> Next i
> End Sub
> IsInserted = True
> Exit Function
> End If
> IsInserted = True
> Exit Function
> End If
> Next ThisLayout
> End Function
> Dim i As Integer
> i = i + 1
> End If
> Next ThisObject
> Next ThisBlock
> End Function
> www.AcadX.com
Message 5 of 11
Well, a nested XRef's insertion point only make sense in the context of the
parent XRef that it is in. I deemed it unneeded to report the insertion
point of nested XRefs, because of what use would it be?
For instance:
XRef name: Diff
XRef path: C:\Temp\Diff.dwg
Inserted at: 12,12,0
Scale factor: 1
XRef name: Drawing2
XRef path: C:\Temp\Drawing2.dwg
Inserted at: 9.63501133246334,30.3961543419182,0
Scale factor: 1
XRef name: X-Diff
XRef path: C:\Temp\X-Diff.dwg
In the above, there are only two XRefs actually placed in the drawing (in
modelspace). The 3rd one, X-Diff, is a nested XRef in Diff.
www.AcadX.com
| Graeme
| > Option Explicit
| > Public Sub Test()
| > Dim i As Integer
| > Set XRef = XRefs(i)
| > Debug.Print _
| > If ynInserted Then
| > Debug.Print _
| > "Inserted at: " & _
| > End If
| > Next i
| > End Sub
| > IsInserted = True
| > Exit Function
| > End If
| > IsInserted = True
| > Exit Function
| > End If
| > Next ThisLayout
| > End Function
| > Dim i As Integer
| > i = i + 1
| > End If
| > Next ThisObject
| > Next ThisBlock
| > End Function
| > www.AcadX.com
Message 6 of 11
Well, my top secret plan is to get all that information, then detach all the
xrefs and then insert them all into the one drawing as blocks. Like bind but
without all the hassle of not being able to bind nested xrefs. I'm sure
someone has probably already done it but I was trying to figure it out
myself.
Graeme
"R. Robert Bell" wrote in message
the
> For instance:
> XRef name: Diff
> Scale factor: 1
> XRef name: Drawing2
> Scale factor: 1
> XRef name: X-Diff
> www.AcadX.com
> | Graeme
> | > Option Explicit
> | > Public Sub Test()
> | > Dim i As Integer
> | > Set XRef = XRefs(i)
> | > Debug.Print _
> | > If ynInserted Then
> | > Debug.Print _
> | > "Inserted at: " & _
> | > End If
> | > Next i
> | > End Sub
> | > IsInserted = True
> | > Exit Function
> | > End If
> | > IsInserted = True
> | > Exit Function
> | > End If
> | > Next ThisLayout
> | > End Function
> | > Dim i As Integer
> | > i = i + 1
> | > End If
> | > Next ThisObject
> | > Next ThisBlock
> | > End Function
> | > www.AcadX.com
Message 7 of 11
Oh I see what you mean. So if I wanted to insert the nested xrefs as blocks
after detaching the whole thing and purging I'd have to do a calculation
relative to the parent xref insertion point and the parent xref scale ?
Graeme
the
> For instance:
> XRef name: Diff
> Scale factor: 1
> XRef name: Drawing2
> Scale factor: 1
> XRef name: X-Diff
> www.AcadX.com
> | Graeme
> | > Option Explicit
> | > Public Sub Test()
> | > Dim i As Integer
> | > Set XRef = XRefs(i)
> | > Debug.Print _
> | > If ynInserted Then
> | > Debug.Print _
> | > "Inserted at: " & _
> | > End If
> | > Next i
> | > End Sub
> | > IsInserted = True
> | > Exit Function
> | > End If
> | > IsInserted = True
> | > Exit Function
> | > End If
> | > Next ThisLayout
> | > End Function
> | > Dim i As Integer
> | > i = i + 1
> | > End If
> | > Next ThisObject
> | > Next ThisBlock
> | > End Function
> | > www.AcadX.com
Message 8 of 11
OK forget what I said about binding drawings. I'm feeling kinda stupid now.
For some reason I thought that xrefs with nested xrefs could not be bound
but I just discovered that they can. But anyway, listing the xrefs is still
gonna be useful !
Message 9 of 11
Yes.
However... binding XRefs that contain resolved XRefs pose no problem. Are
you trying to bind XRefs that contain *unresolved* or unloaded nested XRefs?
www.AcadX.com
blocks
| Graeme
| the
| > For instance:
| > XRef name: Diff
| > Scale factor: 1
| > XRef name: Drawing2
| > Scale factor: 1
| > XRef name: X-Diff
(in
| > www.AcadX.com
the
the
| > | Graeme
| > | > Option Explicit
| > | > Public Sub Test()
| > | > Dim i As Integer
| > | > Set XRef = XRefs(i)
| > | > Debug.Print _
| > | > If ynInserted Then
| > | > Debug.Print _
| > | > "Inserted at: " & _
| > | > End If
| > | > Next i
| > | > End Sub
Boolean
| > | > IsInserted = True
| > | > Exit Function
| > | > End If
| > | > IsInserted = True
| > | > Exit Function
| > | > End If
| > | > Next ThisLayout
| > | > End Function
| > | > Dim i As Integer
| > | > i = i + 1
| > | > End If
| > | > Next ThisObject
| > | > Next ThisBlock
| > | > End Function
| > | > www.AcadX.com
Message 10 of 11
Too late, I didn't see your 3rd post! 😉
www.AcadX.com
"Graeme" wrote in message
now.
still
| gonna be useful !
Message 11 of 11
Yeah, we have to bind some drawings on a project and the drafter was having
a problem with it. It must have been that there are unresolved objects. It
could also be that the engineers stamp was unloaded instead of detached.
Thanks for your help
Graeme
> Yes.
XRefs?
> www.AcadX.com
