X-Ref Relative Path Issue
Hi All,
We are in the process of updating the file structure on the office network, and we are going to have to update the x-refs over 1500 drawings.  To avoid any down time where drawings are not available, I have created a VBA function that will loop through all the drawings, dethatch the x-refs and reattach them using the relative path.  The code is working as I would expect and is re-mapping the x-refs correctly to the relative path, and I can see that in x-ref manager.
The problem is that all the x-refs are vanishing from the drawing.  If I manually attach the x-refs and select relative path it works correctly.  I issue only arises when I automate it.
The code is below, could anyone please let me know what I have got wrong or missed.
Thank you for your help as always
Andy
' loop through selection set and find xrefs
    For Each acadBlock In BlockSelSet
        If acadBlock.Name Like strBlCode & "~" & strFlCode & "*" Then
            ' get xref name and detatch
            strXrefName = acadBlock.Name
            ThisDrawing.Blocks.item(strXrefName).Detach
            'insert new xref
            Set acadXref = ThisDrawing.ModelSpace.AttachExternalReference(ThisDrawing.Path & "\" & strXrefName & ".dwg", strXrefName, insPnt, 1, 1, 1, 0, True)
          End If
    Next acadBlock
    ThisDrawing.Regen acAllViewports
you dont have to detach the xref.
Dim DefBloc As AcadBlock
       set DefBloc = ThisDrawing.Blocks(acadBlock.Name)
       If DefBloc.IsXRef Then '--> xref
        defbloc.path = "..\..\aaa\"    '<-- here the new path (relative or not)
        defbloc.update
      End If
    Next acadBlock
so i think you need to unlock the layer before doing this. (layer.lock = false / true)
sorry i am bad in english
Hi, thank you for you reply, but I get a run time error when i try to run the code like that.
Here the full prog.
just copy and past in vba
run the macro  : Procgen
Sorry it is in french. But if you need explain i can for you 🙂
you just need to replace "c:\" with the path of your bloc XREF.
etap :
1 - find all the bloc INSERT
2 - test if the bloc is a Xref. (isXref)
3 -if it is so check the bloc def in database (.block())
4 - rename the path with : "c:\" + Name of block + ".dwg"
5 - update the bloc.
6 - end
you just need to save the file , close and reopen --> xref updated !!
i am tested this and it works. (iam under acad 2009)
(it work if you name of bloc = name of file.)
bye
'*** function de sélection selon des critères**************************
' ENTREE :
'   Nom de la sélection
'   Liste de format :
'   ex : (0 , "INSERT", 2, "POSTE")  Toujours par 2 : CODE DXF, TYPE RECHERCHE
Public Function SelectAll(NomSelection As String, ParamArray Element()) As Variant
  ReDim FiltreT(0 To ((UBound(Element) - 1) / 2)) As Integer     '--> conteneur Type de filtre
  Dim FilterType As Variant         '--> Type de filtre ex 0 : filtre sur le type d'objet
  ReDim FiltreD(0 To ((UBound(Element) - 1) / 2)) As Variant       '--> conteneur Nom de l'objet
  Dim FilterData As Variant         '--> nom de l'objet pour le filtre
  Dim index As Integer
  Dim Selection As AcadSelectionSet
  Dim erreur As Long
  index = 0
  If NomSelection = "" Then NomSelection = "SelectionAuto"
  On Error Resume Next
  Set Selection = ThisDrawing.SelectionSets.Add(NomSelection)
  If Err.Number <> 0 Then
    Set Selection = ThisDrawing.SelectionSets(NomSelection)
  End If
  Selection.Delete
  On Error GoTo 0
  index = 0
  While index < UBound(Element)
    FiltreT(index \ 2) = Element(index)
    FiltreD(index \ 2) = Element(index + 1)
    index = index + 2
  Wend
  FilterType = FiltreT
  FilterData = FiltreD
  Selection.Select acSelectionSetAll, , , FilterType, FilterData
  Set SelectAll = Selection
End Function
Public Sub Procgen()
  Dim OkErreur As Boolean           '--> Retour de la fonction si erreur (=1)
  OkErreur = False
  Dim ListBloc As AcadSelectionSet      '--> liste des éléments d'un sélection
  Dim Bloc As Variant                   '--> boucle sur les sélections
  Dim DefBloc As AcadBlock              '--> Référence de l'insertion du bloc
'===== récuperation des blocs "INSERT" =====
  Set ListBloc = SelectAll("CHANGEXREF", 0, "INSERT")
'======= Boucle sur chaque élément =========
 For Each Bloc In ListBloc 'pour chaque bloc dans la sélection (dans le dessin)
   Set DefBloc = ThisDrawing.Blocks(Bloc.Name)
   If DefBloc.IsXRef Then '--> c'est un xref
      OkErreur = BoucleRechargeXref(Bloc) '--> Récursivité <--
      If OkErreur Then
        Exit For
      End If
   End If 'si c'est un xref
 Next
 If OkErreur Then
   MsgBox MessageErreurXref, vbCritical + vbOKOnly, "Erreur XRefChange"
 End If
End Sub
Private Function BoucleRechargeXref(InsertBloc As Variant) As Boolean
  OkErreur = False
  Dim Ok As Boolean
  Ok = False
  Dim RetourChariot As String
  RetourChariot = Chr(13) + Chr(10)
  Dim DefBlocXRef As AcadExternalReference  '--> définition du bloc ou du xref
  Dim RepDessin As String               '--> répertoire du dessin en cours
  Dim RepXRefOld As String              '--> répertoire du Xref trouvé (ancien)
  Dim RepXRefTrouver As String          '--> répertoire du XRef trouvé (nouveau)
  Dim OkMaJ As Boolean                  '--> la mise à jour du Répertoire est OK
  OkMaJ = False
'====== Traitement du Bloc Xref ============
  Set DefBlocXRef = InsertBloc
  RepXRefOld = DefBlocXRef.Path
  Set DefBloc = ThisDrawing.Blocks(InsertBloc.Name)
  RepDessin = ThisDrawing.GetVariable("DWGPREFIX")
  ThisDrawing.Utility.Prompt RetourChariot + Separateur + "Xref trouvé : " + DefBlocXRef.Name
  ThisDrawing.Utility.Prompt RetourChariot + Separateur + "-->Rep : " + RepertoireXRef
  RepXRefTrouver = "c:\" & DefBloc.Name & ".dwg"
'===Mise à jour du répertoire ==============
  If RepXRefTrouver <> "" Then '--- Ok trouver alors mise à jour -----
    OkMaJ = True
    DefBlocXRef.Path = RepXRefTrouver
    DefBlocXRef.Update
  Else
    OkErreur = True
    MessageErreurXref = "Répertoire introuvable : " + RetourChariot + _
                        RepXRefOld + RetourChariot + _
                        "pour l'xref : " + DefBlocXRef.Name + RetourChariot + _
                        String(Len(ThisDrawing.GetVariable("DWGPREFIX")) + 20, "=") + RetourChariot + _
                        "dans le fichier : " + ThisDrawing.GetVariable("DWGNAME") + RetourChariot + _
                        "Répertoire : " + ThisDrawing.GetVariable("DWGPREFIX")
  End If
 BoucleRechargeXref = OkErreur
End Function
Nice one, thanks.  That did the trick.
Here is the working code if anyone ever needs it.
Function DWG_UpdateXref()
    Dim FilterType(1) As Integer
    Dim FilterData(1) As Variant
    Dim BlockSelSet As AcadSelectionSet
    Dim acadBlock As AcadBlockReference
    Dim acadXref As AcadExternalReference
    Dim strBlCode As String
    Dim strFlCode As String
    Dim insPnt(0 To 2) As Double
    Dim strXrefName As String
    If Not ThisDrawing.Name Like "*AFM*" Then Exit Function
    'Set global veriables
    If strDwgType = "" Then SetGlobalVar
    ' get building/floor codes
    strBlCode = GetBuildingCode(ThisDrawing.Name)
    strFlCode = GetFloorCode(ThisDrawing.Name)
    ' set insertion point
    insPnt(0) = 0: insPnt(1) = 0: insPnt(2) = 0
    ' create selection set
    FilterType(0) = 8: FilterData(0) = "0"
    FilterType(1) = 0: FilterData(1) = "INSERT"
Retry:
    Err.Clear
    Set BlockSelSet = ThisDrawing.SelectionSets.Add("xRef")
    If UCase(Err.Description) Like "*SELECTION*" Then
        For Each BlockSelSet In ThisDrawing.SelectionSets
            If BlockSelSet.Name = "xRef" Then
                BlockSelSet.Delete
                Err.Clear
                GoTo Retry
            End If
        Next BlockSelSet
    End If
    BlockSelSet.Select acSelectionSetAll, , , FilterType, FilterData
    On Error GoTo 0
            Set acadXref = ThisDrawing.HandleToObject(acadBlock.Handle)
            acadXref.Path = "..\" & strXrefName & ".dwg"
            acadXref.Update
        ElseIf acadBlock.Name Like "EUR-TITLE-*" Then
            ' do the same with the titlesheet
            acadXref.Update
        End If
    Next acadBlock
End Function
