Works in ACAD2000 but not 2004
If you're connecting to AutoCAD from Access you'll need to check the CreateObject/GetObject call. It will likely need to be specific as to version - as in CreateObject("AutoCAD.Application.16") "sussman" wrote in message news:[email protected]... I am running VBA from Microsoft Access and I updated from Acad 2000 to 2004. Now when I run my VBA, ACAD opens up but nothing happens and I get the message "Object Variable or With Block Not Set". What could be causing this and what should I be looking for?
