Working with an exploded block
I am working with a block composed of two smaller blocks, both smaller blocks have their own dynamic properties. I would like to explode my block and then edit the dynamic attributes of one of the resulting blocks, but am running into some issues. I am aware that you can loop through the resulting objects that result from an exploded block and make some property changes. But I am unable to turn one of the resulting objects into an objectblockreference so that I can change one of the dynamic properties. Has anyone ever done this before, or have any ideas that could help me move forward?
To clarify, at the very least, I am trying to set one of the resulting blocks as an acadblockreference after the parent block has been exploded.
norman.yuan
What does it mean by saying "... I am unable to turn one of the resulting objects into an objectblockreference..."? It'd be better if showed your relevant code.
AcadBlockreference returns a Variant value, which is an array of AcadEntity, wihch are the constituent entities in the block definition.  I guess you need to do is the loop through the result array and test each one to see if it is an AcadBlockReference. Following sample code shows this approach:
Public Sub TestExplode()
    Dim ent As AcadEntity
    Dim pt As Variant
    Dim blk As AcadBlockReference
    Dim ents As Variant
    Dim i As Integer
    ThisDrawing.Utility.GetEntity ent, pt, vbCr & "Select block:"
    If TypeOf ent Is AcadBlockReference Then
        Set blk = ent
        ents = blk.Explode
        If UBound(ents) >= 0 Then
            For i = 0 To UBound(ents)
                If TypeOf ents(i) Is AcadBlockReference Then
                    Set blk = ents(i)
                    MsgBox "Entity " & (i + 1) & " from exploded block is block """ & blk.EffectiveName & """"
                End If
            Next
        End If
    End If
End Sub
Norman Yuan
Drive CAD With Code
zhenliang.fu
The sample code is not applicable for external block reference (xref), select the xref block return the error.
