Want to get AcadBlockReference in AcadTable
I want to get cell object in AcadTable
AcadTable only offer AcadTable.GetCellValue(row, column) like
But It's only can use in TextCell. I want get BlockCell's AcadBlockReferences
How can I get AcadBlockReferences in AcadTable's BlockCell?
  • VBA
Ed__Jobe
VBA ActiveX doesn't have a direct way of getting the AcadBlockReference that was inserted in a cell. The best you can do is get the AcadBlock definition that I already showed you. Norman suggested INSERTing a copy and using that. What are you trying to do with it?
Ed
How to post your code.
Now I know make BlockReference Directly is impossible....  So i'm using BlockTable and insert blockreference.
But My BlockReference has Attribute. The same block, but the appearance is different depending on the attributes.
AcadTable.SetAttributes(row, col, attdfid, val) isn't working. because i can't get that tableBlockCell's attributes objectId
