Instead of calling Application.ZoomExtents(), you call Application.ZoomWindow() with the proper window's main/max points. Assume, you only want to zoom to the extents of the ARC itself, then you can call AcadEntity.GetBoundingBox to get the window's min/max points, like this:
Public Sub ZoomToArc()
Dim ent As AcadEntity
Dim pt As Variant
ThisDrawing.Utility.GetEntity ent, pt, vbCr & "Pick the arc:"
If ent Is Nothing Then Exit Sub
Dim minPt As Variant
Dim maxPt As Variant
ent.GetBoundingBox minPt, maxPt
Application.ZoomWindow minPt, maxPt
End Sub
However, with the above code, if you use the AcadDimArcLength object to get the BoundingBox, then the Dim's center point is included with the extents. So, if you need to zoom to the ARC and the ArcLength dimension (without its center), you need to find a way to calculate the window min/max points. it would be tricky. One easier, but not pretty, way could be:
Create a copy of the ArcLength dimension, then explode it;
Get the BoundingBoxex of the exploded entities and the Arc's;
Find the max bounding box of all the bounding boxes;
Delete the exploded entities;
