I am trying to select text entities in Autocad using VBA and store the text string and RBG color values in Excel. But i get only Zero's stored for all the 3 R B G colors. I am not sure what mistake i am making. I also tried extracting color of entity, still does not work. Program is as below.
Can any one help me out.
Option Explicit
' Requires:
' Microsoft Excel Object Library
' go to Tools->Options->General Tab and check 'Break on Unhandled Errors'
Const xlFileName As String = "D:\API\AUTOCAD-VBA\TestFile.xlsx" '<--change existing file name here
Public Sub ExportText()
Dim oSset As AcadSelectionSet
Dim oEnt As AcadEntity
Dim oText As AcadText
Dim i As Long
Dim ftype(0) As Integer
Dim fdata(0) As Variant
ftype(0) = 0: fdata(0) = "TEXT"
Dim dxftype As Variant
Dim dxfdata As Variant
dxftype = ftype
dxfdata = fdata
Dim xlApp As Object
Dim xlBook As Workbook
Dim xlSheet As Worksheet
Dim lngRow As Long, lngCol As Long
Dim color As AcadAcCmColor
On Error Resume Next
Set xlApp = GetObject(, "Excel.Application")
If Err <> 0 Then
Err.Clear
Set xlApp = CreateObject("Excel.Application")
If Err <> 0 Then
MsgBox "Impossible to run Excel.", vbExclamation
End
On Error GoTo Err_Control
With ThisDrawing.SelectionSets
While .Count > 0
.Item(0).Delete
Wend
Set oSset = .Add("$Texts$")
End With
oSset.SelectOnScreen dxftype, dxfdata
xlApp.Visible = True
Set xlBook = xlApp.Workbooks.Open(xlFileName)
Set xlSheet = xlBook.Sheets(1)
xlApp.ScreenUpdating = False
lngRow = 1: lngCol = 1
For Each oEnt In oSset
Set oText = oEnt
Set color = oText.TrueColor
xlSheet.Cells(lngRow, lngCol).Value = oText.TextString
xlSheet.Cells(lngRow, lngCol + 1).Value = oText.TrueColor.Red
xlSheet.Cells(lngRow, lngCol + 2).Value = oText.TrueColor.Green
xlSheet.Cells(lngRow, lngCol + 3).Value = oText.TrueColor.Blue
lngRow = lngRow + 1
Next oEnt
xlSheet.Columns.HorizontalAlignment = xlHAlignLeft
xlSheet.Columns.AutoFit
xlApp.ScreenUpdating = True
xlBook.Save
xlBook.Close
xlApp.Application.Quit
Set xlApp = Nothing
Set xlBook = Nothing
Set xlSheet = Nothing
MsgBox "Done"
Err_Control:
If Err.Number <> 0 Then
MsgBox Err.Description
End Sub
