VBA references by coding
I grabbed this from an earlier message and am having a problem getting
it to work. AutoCAD 14.01, *Misrosoft Visual Basic Extensibility....*
reference is set. I get the *Object variable or With block variable
not set* error, err.number #91. The code has been slightly modified,
and the original code gave the same error.
Monte
Sub AddReference()
Dim objIDE As VBIDE.VBE
Dim FileName As String
FileName = "c:\winnt\system32\my.dll"
On Error GoTo AddReference_Error
Set objIDE = Application.VBE
objIDE.ActiveVBProject.References.AddFromFile FileName
Exit Sub
AddReference_Error:
MsgBox Err.Description & " " & Err.Number, vbCritical, "Cannot Add
Reference "
End Sub
Just to add the code works in 2000, but not in 14.01.
Monte
Hi Monte,
The extensability model is different from R14 to R15, but that's not the
problem!
R14 does not have a VBE property, so the code is not setting objIDE equal to
anything.
Randall Rath
VB Design
Home of the Wonder Llama
http://www.vbdesign.net/cadpages/
Join the WORLDS LARGEST AutoCAD VBA code journal,
its free, its fun.
ok, its peanuts
http://www.vbdesign.net/cadpages/acad.htm
On Thu, 12 Apr 2001 19:02:38 -0700, "Randall Rath"
wrote:
>Hi Monte,
>problem!
>anything.
>Randall Rath
>VB Design
>its free, its fun.
>ok, its peanuts
Randy,
Is there a way to make this work?
Monte
