vba ratio approximation
Amremad
Amremad
i have a question about approximation when i trying to make a macro dependent angles which iam using PI Value (22/7)
or (3.14285714285714)
but the range of the double type isn't enogh to carry (3.1428571428571428571428571428571) cause i need this approcimation or greater than but i can't know how can i make this in vba macro
sorry for my english
if u can help me to calculate this ((3.142857142857142857142857142857142857142857142857142857142857142857142857142857142857142857)
i will be happy
thanks
Alfred.NESWADBA
if you look to >>>this table<<< (dotNET based) you see the datatype "double" is limited and there is no other datatype (except you develop your own) that can hold more decimal places. And at least CPU's and GPU's also can't hold more accuracy then double.
The other question would be: whatfor do you need more accuracy as it will be lost at the point you create a geometry element with that data. Because AutoCAD (or any other CAD-package) is able to hold data more detailed than double.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Amremad
thx mr alfred for fast reply
i know the double type is the max range of floating numbers - but i have a miss calculte becouse i can't get approximation witch i need - my question how can i solve this problem without double type or with other datatype
if you need to write whole code i will
truss_85
This is very curios can you post your code and what would be cause misscalculation need that number of data.
Amremad
Private Function DrawSideElbow(PDM As Double, PL As Double, PR As Double, FT As Double, FOD As Double, FID As Double, FTC As Double, Ang As Double, PB0 As Point, View As Integer)
'On Error Resume Next
Dim L As Double
'Dim R1 As Double
'Dim R2 As Double
Dim PLine As AcadPolyline
Dim P(1 To 4) As Point
Dim PB1 As Point
Dim Ang1 As Double
Dim Ang2 As Double
Dim X As Double
Select Case View
    ' Draw Side View
    Case 0
        'draw first elbow part
        L = PL - (PR + FT)
        'R1 = PR + PDM / 2
        'R2 = PR - PDM / 2
        PB1.X = PB0.X - L: PB1.y = PB0.y + L
        P(1) = GetPoint(PB0, -90, (L + PR + PDM / 2))
        P(2) = GetPoint(PB1, -90, (PR + PDM / 2))
        P(3) = GetPoint(PB1, -180, (PR + PDM / 2))
        P(4) = GetPoint(PB0, -180, (L + PR + PDM / 2))
        Set PLine = DrawPolyLine(P())
        PLine.SetBulge 1, Tan(90 / (22 / 7))
        PLine.Layer = "BIO-PIPE1"
        P(1) = GetPoint(PB0, -90, (L + PR - PDM / 2))
        P(2) = GetPoint(PB1, -90, (PR - PDM / 2))
        P(3) = GetPoint(PB1, -180, (PR - PDM / 2))
        P(4) = GetPoint(PB0, -180, (L + PR - PDM / 2))
        'draw first flange
        'PF.X = P0.X + L
        'PF.y = P0.y
        'DrawFlange FOD, FID, FT, FTC, Ang, PF, DegToRad(-90)
        'draw second flange
        'PF.X = P0.X - PR
        'PF.y = P0.y - PR - L
        'DrawFlange FOD, FID, FT, FTC, Ang, PF, -180
    Case 1
    Case 2
End Select
End Function
Public Function GetPoint(P As Point, Angle As Double, R As Double) As Point
        'Dim X, Y As Double
        GetPoint.y = P.y - (Sin(DegToRad(Angle)) * R)
        GetPoint.X = P.X + (Cos(DegToRad(Angle)) * R)
End Function
Private Function DegToRad(Ang As Double) As Double
DegToRad = Ang * (22 / 7) / 180
End Function
Private Function RadToDeg(Ang As Double) As Double
RadToDeg = Ang * 180 / (22 / 7)
End Function
        'Dim X, Y As Double
End Function
Alfred.NESWADBA
have you ever checked that
PI - 22/7 = 0,00126448926734961868021375957764
So you have a difference as 22/7 is not equal to PI.
What you can use instead to calculate PI is:
PI = 4 * arctan(1)
HTH, - alfred -
Alfred NESWADBA
Amremad
thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx thx
iam soo happy
it's work very good
