Run-time error -2147418111 Automation error. Call was rejected by callee.
Message 1 of 13
thanks for any help
little VBA test routine :
reading xls file with 5 tif file names, creating dwg with same ref name and attaching the same tif to the new dwg, then save and go next.
With the msgbox line active it works just fine. With the msgbox line ' as comment the error occurs.
 code attached
Replies (12)
Message 2 of 13
Alfred.NESWADBA
don't see attached code 😉
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 13
doc attached was a docx, here is the body (thanks) :
Dim ExcelApp As Object
Dim AcadApp As Object
Sub Tif_DWG()
        'Routine that reads raster (tif) filenames from xls sheet, creates a dwg based on each tif name
        'and attaches the same tif to that dwg. Author Nicolas Tobbackx - 11 april 2012
        'define Excel file variables
                Dim appExcel As Excel.Application 'Excel application
                Dim wbExcel As Excel.Workbook 'Excel filename
                Dim wsExcel As Excel.Worksheet 'Excel sheet
                Set appExcel = Excel.Application
                Set wbExcel = appExcel.Workbooks.Open("c:\temp\test_tif_2dwg.xlsx")
                Set wsExcel = wbExcel.Worksheets("Sheet1")
        'define local variables
                Dim i As Integer
                Dim Tif_feednewname As String
                Dim Newname As String
        'define AutoCad variables
                Dim appAcad As AcadApplication
                Dim docAcad As AcadDocument
                Dim Layout As AcadLayout
                Dim insertionpoint(0 To 2) As Double
                Dim rasterObj As AcadRasterImage
                Dim Mspace As AcadModelSpace
  'read xls file
            For i = 1 To 5
            Tif_feednewname = Cells(i, 1)
           'create AutoCad file and insert tif in dwg
             Set docAcad = Application.Documents.Add
                insertionpoint(0) = 0: insertionpoint(1) = 0: insertionpoint(2) = 0
            'MsgBox "adding raster"
               ‘ZoomAll
           Set rasterObj = docAcad.ModelSpace.AddRaster(Tif_feednewname, insertionpoint, 1, 0)
                rasterObj.ScaleFactor = 1
                Set Layout = docAcad.ModelSpace.Layout
                Newname = (Tif_feednewname & "_dwg")
                docAcad.SaveAs (Newname)
            Next i
End Sub
Message 4 of 13
Alfred.NESWADBA
what should this line do?
At what line does the code raise up the exception?
Does the code crash at every drawing beginning with the first one or does it happen after some drawings were processed already?
Have you tried to pass a valide template-file when creating a new drawing with this statement:
Is it a help if you close the drawing after inserting the image? Depending on size of TIFF, on memory and operating system you are using, on AutoCAD release it may be problematic to have multiple files opened having large images referenced.
- alfred -
Alfred NESWADBA
Message 5 of 13
Thank you very much for your reply.
The set layout line does nothing, it is indeed redundant
the code crashes on the first time. So no dwg gets created at all.
I tried with a template file but that does not change either.
I think the msgbox (and clicking OK ?) command sort of activates Autocad so Autocad is ready and listening and can start working.
Message 6 of 13
Alfred.NESWADBA
so what is the line now that's execution results in the exception?
To get the AutoCAD application-window focused you can try to use this statement
AppActivate ThisDrawing.Application.Caption
- alfred -
Alfred NESWADBA
Message 7 of 13
Thanks again,
the activate command does not change anything
program blocks on the "set rasterobj" line .. (or any command in autocad that would appear there).
Message 8 of 13
Alfred.NESWADBA
sorry that I can't try the code now (as I think it would be a lot of work to get it reproduced) and so I only can show up some ideas (without testing it).
What about changing the statement to
Set rasterObj = docAcad.database.ModelSpace.AddRaster(Tif_feednewname, insertionpoint, 1, 0)
or this statement
Set rasterObj = ThisDrawing.ModelSpace.AddRaster(Tif_feednewname, insertionpoint, 1, 0)
That I don't understand. As long as your code is running and you don't use SendCommand there could not be any commands called.
- alfred -
Alfred NESWADBA
Message 9 of 13
thanks,
the "database" or "thisdrawing" versus (docAcad) argument does not change anything.
With any autocad command I mean for instance "zoom all" or regen or place circle etc.;
it's like Autocad does not "listen" (or is not active). The msgbox seems to activate.
So again, everything works fine WITH the msgbox and withe the 'commented msgbox (so without msgbox) if gives an error.
We tried on different machines here and same behaviour on all machines. We also tried wait, sleep, timer, ..
thanks,
Nico
Message 10 of 13
Alfred.NESWADBA
I have to avoid your Excel-handling (as this would use to much time for me), but tried the following code (as the problem seems to be isolated to the AddRaster-codeline) to come as close as possible to your problem-code-line.
I have a directory C:\TEMP and within that I have the files 1.TIF, 2.TIF, 3.TIF
Then I started this code, that creates for every image a new file and inserts then the correspondig TIF-file.
So the question is now: does that code run in your AutoCAD?
Public Sub test()
   Dim i As Integer
   Dim tAcadDoc As AcadDocument
   Dim tAcadApp As AcadApplication
   Set tAcadApp = ThisDrawing.Application
   Dim tInsPnt(2) As Double
   For i = 1 To 3
      Set tAcadDoc = tAcadApp.Documents.Add
      Dim tFileName As String
      tFileName = "C:\TEMP\" & CStr(i) & ".tif"
      Dim tImg As AcadRasterImage
      Set tImg = tAcadDoc.ModelSpace.AddRaster(tFileName, tInsPnt, 1, 0)
   Next
End Sub
It would also be great to know what AutoCAD release and servicepack you are running, also if plain AutoCAD or any vertical product base on AutoCAD.
- alfred -
Alfred NESWADBA
Message 11 of 13
Thank you very much indeed again for your help.
My colleague Francis Nahoé found a solution meanwhile with - i Guess-- A similar approach.
He added a timer called "tempo". see below
Wishing you all the best,
Nico Tobbackx -  Belgium
Sub Example_AddRaster(imageName As String)
 ' This example adds a raster image in model space.
 ' You should change this example to use
 ' a raster file on your computer.
 Dim insertionPoint(0 To 2) As Double
 Dim scalefactor As Double
 Dim rotationAngle As Double
 insertionPoint(0) = 0#: insertionPoint(1) = 5#: insertionPoint(2) = 0#
 scalefactor = 1#
 rotationAngle = 0
 On Error Resume Next
 ' Creates a raster image in model space
 Set rasterObj = ActiveDocument.ModelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotationAngle)
 If Err.Description = "File error" Then
  MsgBox imageName & " could not be found."
  Exit Sub
 ZoomExtents
End Sub
Sub Pause(Tempo)
 Dim t As Date
 'Tempo en seconde
 t = Timer + Tempo:
 Do Until Timer > t: DoEvents: Loop
End Sub
Sub test()
 For i = 1 To 5
  Documents.Add
  Call Pause(1)
  Call Example_AddRaster("c:\Raster.tif")
 Next i
End Sub
Message 12 of 13
Thank you very very very much. I  was confused by this problem for many days. This  small code just solved my problem. Thank you.
谢谢,非常感谢。
      huaxiamengqing for china
Message 13 of 13
THANK YOU SO MUCH!!!
Adding the code for the paus solved my problem totaly !!!!!
