vba problem
vba problem
vba problem
hi
common dialog control does not work in autocad vba 2016 64 bit. is there any body know about this problem.
thanks
norman.yuan
It is known issue because of AutoCAD VBA being 64bit since AutoCAD 2014, if the installed AutoCAD is 64bit. There are simply very few 64-bit equivalents to 32-bit VB/VBA components to use.
If your VBA program only needs to have an open file dialog, you can use VBA code to call Windows API. See this discussion:
https://forums.autodesk.com/t5/visual-basic-customization/vba-7-1-commondialog-lost/m-p/3841702#M968...
However, if you have relatively complicated VBA program that uses 32-bit UI components/ActiveX Controls, you would not be lucky enough to find 64-bit equivalent to port your old 32-bit VBA to 64-bit. You probably need to rewrite the program with newer technology, such as AutoCAD .NET API.
Norman Yuan
Drive CAD With Code
