VBA object can not modify TrueColor ColorMethod
saboh12617
saboh12617
When i import an iges file in my drawing the objects color are defined in Hard, not by layer.
I would like to change it back to the layer color.
I tried a simple loop like
 For Each obj In acadDoc.ModelSpace
    obj.TrueColor.ColorMethod = acColorMethodByLayer
    'obj.TrueColor = obj.Layer.TrueColor
 Next obj
But for some reason when i open the LocalWindow view i see that the loop is not modifying the object color method, which is stuck on "acColorMethodByACI".
How can i change this?
I tried also calling the layer color as visible on the commented line but it doesnt work either (since the layer properties returns the layer name and not the actual layer, and i think it would just copy the color, not put an equivalence).
Norman_Yuan
You might want to try this way:
Dim clr As AcadAcCmColor
    Set clr=obj.TrueColor
    clr.ColorMethod = acColorMethodByLayer
    obj.TrueColor = clr
 Next obj
The syntax looks strange, but this is how to do it. Also, pay attention to this line:
obj.TrueColor = clr
Note: no keywork "Set" preceding!
Norman Yuan
Drive CAD With Code
saboh12617
Thank you it works perfectly, objects colors are back to "ByLayer".
A bit tricky, i would have spent a lot of time figuring it out by myself...
As i understand it, redefining the CAD object TrueColor color method is not sufficient as we need to "recall" the CAD object that its TrueColor property object got modified. Seems like pointers are not updating correctly.
Thank you for the workaround.
