VBA export drawing to bmp
tuli1954
tuli1954
Trying to export a dwg to a bitmap format.
Neither of the two options shown below worked.
What am I missing?
Thank you
Sub Export_image()
Dim exportFile As String
exportFile = "c:\tmp\image.bmp"
Dim sset As acadSelectionSet
ThisDrawing.SelectionSets.Item("TEST").Delete
Set sset = ThisDrawing.SelectionSets.Add("TEST")
' option 1
Thisdrawing.saveasbitmap exportFile, 1200, 800
' option 2
Thisdrawing.export expotfile,"bmp", sset
End Sub
seabrahenrique
Try this:
Sub Example_Export()
    ' Define the name for the exported file
    exportFile = "c:\tmp\image"
    ' Create an selection set with all elements in a drawing
    Dim sset As AcadSelectionSet
    Set sset = ThisDrawing.SelectionSets.Add("TEST8")
    sset.Select acSelectionSetAll
    ' Export the current drawing to the file specified above.
    ThisDrawing.Export exportFile, "bmp", sset
End Sub
I guess you created your selection set but they don't have elements... so, you also have to add elements in your selection set using " sset.Select acSelectionSetAll" or another method.
Another thing is: i an "exportfilename" variable, you don't have to use de extension of image. Because you already will to specify that in a a function "Thisdrawing.export expotfile,"bmp", sset"
I hope can help u 🙂
tuli1954
It works, Thank you
seabrahenrique
@tuli1954 Nice!
Remember mark the answer as solution 🙂
Thanks!
