David, I found this same problem with XP Pro, Office, and TuTu. If you
install Office (or some components of Office) *after* TuTu, TuTu will hate
you until you reinstall it. Autodesk tells us that AutoCAD has to be
installed *after* Office.
R. Robert Bell, MCSE
www.AcadX.com
"David M. Gardner" wrote in message
news:AD4AF28480FFB2C308D82A93D5DA5E01@in.WebX.maYIadrTaRb...
> That is not true. AutoDesk does support some products on XP. The rest
are
> in testing. By the way is just started to work out of the blue. I did
> nothing and it started to work. Strange eh?
> Dave Gardner
> "Laurie Comerford" wrote in message
> news:FCAA30E782F7A206ADD6541FB7930588@in.WebX.maYIadrTaRb...
> > Hi David,
> > The fact that Autodesk tells us that none of their products are
supported
> on
> > XP probably relates to this sort of (relatively) obscure problem.
> > Laurie Comerford
> > CADApps
> > www.cadapps.com.au
message
> > news:BF979192FFFF14698075DFD73FAA75DB@in.WebX.maYIadrTaRb...
> > > Is there some sort of problem running VBA on XP Pro. Anytime I go to
> > start a VBA that I wrote or get in to the VBA Manager it crashes.
> > > Dave Gardner
