VBA controls in layout
Is possible to create VBA controls in paperspace or modelspace to run macros ?
I would like to add some buttons to a layout, to enable/disable some layers, and avoid making multiple layouts to show different layers.
Ed__Jobe
No, you would use CUI elements to run vba macros. e.g. toolbars, menus, palette, or ribbon. You can also use lisp to make a command that can be typed at the command line.
Ed
How to post your code.
Alfred.NESWADBA
What would happen on a system which does not have the VBA-Enabler installed when they open this drawing/layout? 😉
Try layerstates.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
