VBA code to send email
mohandis2
mohandis2
I could make a routin that prints my drawing in pdf, I want to send these pdf files via an email using outlook, can anyone help?
Regards.
norman.yuan
To send email from your AutoCAD VBA code via Outlook, you need to automate Outlook through its COM API. Needless to say, Outlook has to be installed and ready for the current log-in user to send email. The code to make Outlook send an email is fairly simple:
Public Sub SendEmail()
    Dim outobj As Object
    Dim mailobj As Object
    Dim strMsg As String
    On Error Resume Next
    Set outobj = GetObject(, "Outlook.Application")
    If outobj Is Nothing Then
        Set outobj = CreateObject("Outlook.Application")
    On Error GoTo 0
        MsgBox "Cannot obtain Outlook application object!"
        Exit Sub
    Set mailobj = outobj.CreateItem(0)
    strMsg = "This is test email"
    With mailobj
     .To = "norman.yuan.fsj@gmail.com"
     .Subject = strMsg
     .Send
    End With
    'Clear the memory
    Set outobj = Nothing
    Set mailobj = Nothing
End Sub
 The code uses late binding (that is, no need to set reference to Outlook library). You need to add a bit more code to add attachment to the email, though. You can open Outlook VBA editor and use Object Browser to find out how to add attachment to an email.
Depending on Outlook version and its security settings, a security warning window may pops up, saying something like " an application is trying to use Outlook...." and user may have to click OK to allow the code to continue.
Norman Yuan
Drive CAD With Code
mohandis2
Thanks for the reply, it worked fine.
My other problem is how to detect selected sheets only.
