create new mleader style in Visual basic
hi
i need create new mleader style. somebody can helpme?
set style_mleader=autocad.application.ActiveDocument.????????. add("New style").......????
norman.yuan
AcadMLeaderStyle is stored in AcadDocument.Dictionaries (named dictionaries of the drawing database). AutoCAD VBA help document provides a code sample of how to access/ccreate it:
Go to AutoCAD VBA Editor, open Object Browser, select "AcadMLeaderStyle", then click "?" button on top of the Object Browser. This opens VBA Help Document on the topic of "MLeader Style". In the article, there is a link to a code sample.
HTH
Norman Yuan
Drive CAD With Code
thanks norman.juan for reply....
i tried that....
norman.yuan
In the red-highlighted line of code, you need to remove the bracket
xxxx.AddObject "ccccc", "ddddd"
Or you add Call at beginning:
Call xxxx.AddObject("cccc", "dddd"),
Or if you want to refer the returned object in the code following, you need:
Dim myMLealerStyle as Object
Set myMleaderStyle=xxxx.AddObject("cccc","dddd")
Norman Yuan
Drive CAD With Code
norman.yuan
Norman Yuan
Drive CAD With Code
I added that and worket:
thank you very much
