vba calculate length of line selected help
I have avba project i am working on which asks the user to select apolyline on the drawing. The code then gets the length of the line but rturns to abiut 6 decimal places.
Question 1.
How do i get it to return the length to 2 decimal places only?
Question 2.
If the user selects anumber (ie 2, 3, 4 etc) from a combobox on a user form in the project, how do i get the length of the line multiplied by the selected number?
I have listed the code i have at present below. I think that is all.
Regards JohnB
Public Sub AddTendon()
Dim intFilterType(0 To 0) As Integer
Dim varFilterData(0 To 0) As Variant
Dim objSelectionSet As AcadSelectionSet
For Each objSelectionSet In ThisDrawing.SelectionSets
If objSelectionSet.Name = "AddTendon" Then
objSelectionSet.Delete
Exit For
End If
Next objSelectionSet
Set objSelectionSet = ThisDrawing.SelectionSets.Add("AddTendon")
ThisDrawing.Utility.prompt "Select a tendon..." & vbCrLf
intFilterType(0) = 0
varFilterData(0) = "LWPOLYLINE"
objSelectionSet.SelectOnScreen intFilterType, varFilterData
If objSelectionSet.Count > 0 Then
strTendonLength = CalcTendonLength(objSelectionSet(0))
frmAddTendon.Show
Else
Exit Sub
End If
End Sub
Public Function CalcTendonLength(objPolyLine As AcadLWPolyline) As Double
Dim varEntities As Variant
Dim dblLength As Double
Dim intIndex As Integer
dblLength = 0#
varEntities = objPolyLine.Explode
For intIndex = LBound(varEntities) To UBound(varEntities)
If TypeOf varEntities(intIndex) Is AcadLine Then
dblLength = dblLength + varEntities(intIndex).Length
ElseIf TypeOf varEntities(intIndex) Is AcadArc Then
dblLength = dblLength + varEntities(intIndex).ArcLength
End If
varEntities(intIndex).Delete
Next intIndex
CalcTendonLength = dblLength
End Function
"johnbortoli" wrote in message news:24750915.1109903967538.JavaMail.jive@jiveforum1.autodesk.com... > I have avba project i am working on which asks the user to select apolyline on the drawing. The code then gets the length of the line but rturns to abiut 6 decimal places. > Question 1. > How do i get it to return the length to 2 decimal places only? Debug.Print Round(25.345243985744, 2) or if you're dealing with strings look at the Format function hth > Question 2. > If the user selects anumber (ie 2, 3, 4 etc) from a combobox on a user form in the project, how do i get the length of the line multiplied by the selected number? now I'm not sure what you're exactly asking cause I'm sure you know... dLen = 25.25 lNum = 4 dRes = dLen * lNum so I think i'm missing something in your question... Mark
