VBA Autocad Compart two shapes
jalal.mousa
jalal.mousa
is there any way to compare set of  shapes (set of shapes always equal or partial of shape 1) shape 1 to determine if you need full size pc, 1/2 size or 1/4 pc
can this be achieved by comparing Area, perimeter and length of vertics ? or is there easier way ?
Ed__Jobe
You should be able to just use the area.
Function PartsRequired (area As Double) As Double
   ' Default are is .3 * .6 = 1.8
   Select Case (area/1.8)
      Case Is >= 0 And <= 0.25
          PartsRequired = 0.25
      Case Is >= 0.26 And <= 0.5
          PartsRequired = 0.5
      Case Is >= 0.51 And <= 1
          PartsRequired = 1
   End Select
End Function
Ed
How to post your code.
jalal.mousa
Hi Ed,
thanks for help but i wish it was that easy in my case.
In my case size (length and width) of pc i am comparing to shape 1 will determine also if you can use 1/2, 1/4 or you should go to full
see attached sketch both shapes have similar area but in case 1 you can get away with 1/4 of shape 1 in case 2 you must go with 1/2
in other words i have to consider length of shape sides and Area in same time to make sure both areas and length can still allow me to use 1/4 or 1/2 or if i should go with full pc
Ed__Jobe
It just means that you have to add more variables to your equation to figure out each case. You determine the criteria. Such as if  one of the sides is more than half of 0.6, then use a full sheet. You just need to figure out the math.
Ed
