VBA and the AutoCad Command Line
Message 1 of 1
I wrote a VBA program that is standalone and got stuck when writing script for controlling and monitoring the Command Line. I have written the Code properly to initiate the Break Command and after that I do not know how to switch back and forth so that VBA controls what happens and what gets inputted. I had intended to select/highlight a line, then try to have VBA select First Point (instead of Second Point), switch back to Acad Document visible, select the First Point then select the Second Line then back to the VBA written window for the next procedure. Does anyone have any sample code for editing and controlling the Command Line in the middle of a Modify Command?
THX,
Dan McRae
Replies (0)
