VBA and DVB newbie question
h_s_walker
Mentor Mentor
h_s_walker
Ok I'm not a VB newbie not by a longshot, but VBA and Autocad. TOTAL NEWBIE.
Now I've converted a VB program of mine to vba and running it from VBA Manager works as expected.
1. A dialog box pops up.
2. The user enters a load of numbers.
3. A polyline is drawn.
4. Dialog box closes.
Now how can I add that dvb to a button so that I can click on it and have it run.
ALSO
I would like to check if a layer exists in the drawing. If the layer doesn't exist create it, otherwise continue with the rest of the program.
The layer by the way is called REINFORCEMENT
Howard Walker
Left Handed and Proud
norman.yuan
To run VBA macro from menu/toolbar/ribbon item is not much difference to run a LISP command: you can simply write an AutoCAD scrip macro to record your command line action and assign it to your menu/toolbar item. But, you need to make sure the *.dvb is loaded, which you can load on AutoCAD startup by using acad.dvb, or acad.lsp...
However, a much simple way would be using lisp statement (vl-vbarun...), which load a *.dvb, if not yet loaded, into AutoCAD and runs a VBA macro defined in that *.dbv.
Assume you know how to customize menu/toolbar/ribbon with CUI command: define a command, and assign this macro to the command:
^C^C^C(vl-vbarun "myApp.dvb!myModule.MyRoutine")
Then you can have menu item/toolbarbutton/ribbon item this command.
Notice that the you can also include full file path for the *.dvb name. If not path, AutoCAD will search support paths for the *.dvb file to load.
As for check whether a layer exists, it is fairly easy in AutoCAD VBA, pseudo-code:
Dim lay as AcadLayer
Dim exists As Boolean
For Each lay in ThisDrawing.Layers
  If UCase(lay.Name)=UCase(targetLayerName)
    exists=True
    Exit For
  End If
Next
If Not exists Then
  ''Create new layer here
End If
HTH
Norman Yuan
Drive CAD With Code
h_s_walker
Here's the DVB file attached.
You'll notice that in no part of it does it say "Show this form" However at the end it does say "Hide the form".
It will run from VBA as expected. However I want to run it from a button
Howard Walker
h_s_walker
Stupid me forgot to add a module for my macros
Program now works as expected
Howard Walker
norman.yuan
Your VBA project is "not completed", because it lacks a VBA macro (VBA command), so you can "run" the form inside VBA editor, but no way to run it outside VBA editor as user.
The very basic way to run VBA code for user (who knows nothing about VBA/VBA Editor) is to enter command "VBARUN" (or ALT+F8), which bring up VBA Macros winodw, which lists all available VBA macros. In your VBA Project, this window is empty because there is no VBA macro your VBA code. You need to create one, like this:
1. in VBA editor, add a module, give it a proper name, if preferred, but it has default name, like "Module1";
2. Add following code to start the form:
Option Explicit
Public Sub ShowMyForm()
    WIBeam.show
End Sub
Now, if you enter command "VBARUN", you will see a VBA macro available for user to run.
Now you can incorperate this VBA macro with the menu/toolbar macro as I explained in previous reply.
HTH.
Norman Yuan
Drive CAD With Code
h_s_walker
Already done.
You don't need Option Explicit if it's just showing a form
Howard Walker
