VBA and Autodesk Map 2004
Hi
I've been experiencing some trouble on my PC with my VBA codes. I have two laptops and my collegues aren't having trouble. So I'm stuck...
When I try to run the VBA code (Say, CODE1) from one specific tool package it says CODE1.dvb!Name.tool "Execution error". When going to the VBA-manager the packages are loaded correctly but when I try to load them to see what's inside I get "Error in Loading DLL". And it's not "OK"! Neither is de "Help" helping...
Even stranger: When I execute an other script first (Say CODE2), that seems to work fine. But CODE1 is not working. Executing CODE1 first, getting an error and then CODE2, then CODE2 doesn't work either. So, I guess it has something to do with CODE1. Although it works like a charm on other stations.
Thanks for the help
Arnout
Norman_Yuan
Back to when I was using AcadMap 2004/6, I remembered that Acad Map2004/6 often suddenly gave error "Execution Error", usually after a windows update was applied to the OS (WinXP). In this case, do AutoCAD Map installation reparing would fix it. So, I suggest you try to repair AcadMap installation first.
Norman Yuan
Drive CAD With Code
