VBA Add document then Add layer got -2147418111 Automation error
Dear all,
   I got an error when add a layer after creating a new document, do you have any suggession?
Env.
 Sub test()
    On Error GoTo err_handle
    Dim app As AcadApplication
    Dim sleepCount As Long
    Set app = GetObject(, "AutoCAD.Application")
    For i = 1 To 10
        sleepCount = 0
        app.Documents.add "acadiso.dwt"
        'AddDrawingInfoLayer 'if I use this line directly,then will get an error: -2147418111 Automation error
        ' wait until the layer created, it's very slow, mornally it taks a long time to do it..
        Do While AddDrawingInfoLayer = False
            sleepCount = sleepCount + 1
            Wait 0.01' wait 0.01 second
        Loop
        Debug.Print i & " sleep " & sleepCount & " seconds"
        ThisDrawing.SaveAs "C:\temp\" & i & ".dwg"
        ThisDrawing.Close False
    Next i
    Exit Sub
err_handle:
    Debug.Print Err.Number
    Debug.Print Err.Description
End Sub
Private Function AddDrawingInfoLayer() As Boolean
    ThisDrawing.Layers.add "new_layer"
    AddDrawingInfoLayer = True
    Exit Function
err_handle:
End Function
Private Function Wait(seconds As double)
    Dim varStart As Variant
    varStart = Timer
    Do While Timer < varStart + seconds
    Loop
End Function
   Autocad 2013 64bit, windows 8 64bit. 8GB ram and i7-3770 cpu
Thanks in advance!
Alfred.NESWADBA
Sorry, I don't get exceptions when I run your code without time-loops (which should not be necessary at least).
The only idea I have is you have anything running parallel that "reacts" on layer additions/modifications, e.g. do you have the layermanager open while running your code? Or do you have any applications/apps/tools installed?
What you might try "DoEvents" instead of the time-loops:
DoEvents
'        Do While AddDrawingInfoLayer = False
'            sleepCount = sleepCount + 1
'            Wait 0.01 ' wait 0.01 second
'        Loop
And - I guess you know that - AutoCAD 2013 is not supported for Win8.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Thanks very much for your reply!
  I don't know why, if I delete wait code, then the layer cannot created, and if I change to "Wati 0", then i can work. Strange. I will test your code, thanks again!
Alfred.NESWADBA
>> I don't know why
Again the question: do you have the layermanager open while your code runs (and crashes)?
- alfred -
Alfred NESWADBA
