VB6 error initializing Acad
Why do the following lines of code return an error in VB6 when I use them as
stated in the help files? By the way, I am using LDD2i.
Dim appAcad as AcadApplication
Dim objAcadMap as AcadMap
Set appAcad = GetObject(, "Acad.Application")
set objAcadMap as appAcad.GetInterfaceObject("AutoCADMap.Application")
"Tim Dear" wrote in message
news:3D995E23A3B89B9446943D81C70912F3@in.WebX.maYIadrTaRb...
as
Hello Tim,
It looks like your running into the early binding
issue in the Map Automation Library.
Unfortunately, the Map Library only supports
early binding from within Acad VBA. For VB
you must declare all of the Map objects using
late binding...
In other words, declare all Map objects as Object.
Dim objAcadMap as Object
Cheers-
rdh.
