Using Str$ to convert integers
Message 1 of 8
I have this simple code:
Str$(iVertex + 1)
Say that iVertex is 29....
The string returned from this call is " 30"
Why am I getting the space before the number in the string?
It should be "30"
This happenes for all of the values that I attempt to convert into strings.
Thanks for any help.
Andrew
Replies (7)
Message 2 of 8
Trim(Str$(iVertex + 1))
wrote in message news:5192291@discussion.autodesk.com...
Str$(iVertex + 1)
It should be "30"
Andrew
Message 3 of 8
From the elusive Help file for Str Function:
Remarks
When numbers are converted to strings, a leading space is always reserved
for the sign of number. If number is positive, the returned string contains
a leading space and the plus sign is implied.
Use the Format function to convert numeric values you want formatted as
dates, times, or currency or in other user-defined formats. Unlike Str, the
Format function doesn't include a leading space for the sign of number.
Str$(iVertex + 1)
It should be "30"
Andrew
Message 4 of 8
Or use
Trim(Str(iVertex +1))
Saludos, Ing. Jorge Jimenez, SICAD S.A., Costa Rica
"Jeff Mishler" wrote in message
news:5193166@discussion.autodesk.com...
Remarks
Str$(iVertex + 1)
It should be "30"
Andrew
Message 5 of 8
Right, that's what joeparker said, too. I was merely answering Andrew's
question of "Why does it do it" with a quote from a source he could have
looked up just as easily as I did........
"Jorge Jimenez" wrote in message
news:5193221@discussion.autodesk.com...
Or use
Message 6 of 8
Sorry Jeff, I did not see JoeParkers post.
news:5193222@discussion.autodesk.com...
Or use
Message 7 of 8
Thanks to everyone for their comments, answers, gripes etc..
Much appreciated.
Andrew
Message 8 of 8
Skip the Trim and change your Str$ function to CStr and you get no spaces
wrote in message news:5193393@discussion.autodesk.com...
Much appreciated.
Andrew
