Using saveas in VBA
Using saveas in VBA
Using saveas in VBA
Hi, im trying to use the saveas command in AutoCAD 2000 VBA
without much success.
the line of code i'm using is:
ThisDrawing.SaveAs "c:\1\test.dwg", acR13_dwg
and it doesn't seem to work.
the drawing is not saved.
where am i going wrong.
thanks in advance
MICK
Can you show some more of your code. So long as the
folder '1' exists, the code you posted works fine here.
acR13_dwg
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
without much
success.
ThisDrawing.SaveAs
the drawing is
not saved.
thanks in advance
MICK
It should work fine like this:
acadApp.ActiveDocument.SaveAs ("filename")
But the filename must be accessible (The dir must exist, the filename must be readonly etc.)
