Update to Access via ADO
I have a VBA application which records attributes of specialized blocks to
an Access database. I am connecting via ADO (v2.5). I am stumped trying to
figure out how to update records in Access. I have been unable to find any
useful information except that I may NOT be able to UPDATE with ADO and
should switch back to DAO instead. If anyone has experience with UPDATEs on
Access recordsets with ADO, I appreciate hearing from you.
Thank you
Tom
Dim rsJob As ADODB.Recordset
rsJob.Update
have you done this, and it doesn't work?
Kevin
"Java Yaboh" wrote in message
news:566C7E9E26967E38E63B8B3FAF87C73C@in.WebX.maYIadrTaRb...
on
> Thank you
> Tom
Kevin,
Sorry, I haven't used Outlook for newsggroups before...
I have added the relevant section of code below. When I run it with .Update
after opening the connection, I get a "Syntax error in FROM clause."
message.
Set oConn = New ADODB.Connection
Set oRS = New ADODB.Recordset
oConn.Open CONNECT_STRING
strSQL = "SELECT * FROM Hydrant WHERE Hydrant.HydrantId = '" & intHydId &
"'" '', HydrantServiceLine
With oRS
.CursorLocation = adUseClient
.CursorType = adOpenDynamic
.LockType = adLockOptimistic
.Open strSQL, oConn, , , adCmdTable
.Update
''.EditMode
!HydrantX = HydrantX
!HydrantY = HydrantY
!PipeLength = sngConnPipeLength
''.Update
.Close
End With
The resulting query is: SELECT * FROM Hydrant WHERE Hydrant.HydrantId =
'9999'
When I run it in the query designer it works fine and returns the requested
recordset. Just for background, my coding background is Delphi and Java -
I'm new to VBA.
Thank you for your help,
Tom
"Kevin Terry" wrote in message
news:37B4C5CD998B6ABBA140A205971EEA8B@in.WebX.maYIadrTaRb...
> rsJob.Update
> Kevin
to
to
any
> on
> > Thank you
> > Tom
I don't see anything wrong with that FROM clause. However, the "Hydrant." is
unnecessary and certainly could be removed. Try it without that.
Is "intHydId" really a string? Its name suggests integer, but then the
concatenation would fail.
How about just updating the table with SQL? The DBMS driver is heavily
optimized for doing such manipulations. I forget the VBA convert-to-string
functions, but something like:
strSQL = "Update Hydrant set HydrantX = " & _
MakeIntoString(HydrantX) & _
", HydrantY = " & _
MakeIntoString(HydrantY) & _
", PipeLength = " & _
MakeIntoString(sngConnPipeLength) & _
" where HydrantId = '" & intHydId & "'"
If you do this, it's most convenient to use the Execute method of the
Connection object, because then you get the number of records affected.
jrf
Member of the Autodesk Discussion Forum Moderator Program
Please do not email questions unless you wish to hire my services
In article <26300F275FFC704C5B2C613197605E8E@in.WebX.maYIadrTaRb>, Java Yaboh
wrote:
> Kevin,
> message.
> With oRS
> ..CursorLocation = adUseClient
> ..CursorType = adOpenDynamic
> ..LockType = adLockOptimistic
> ..Open strSQL, oConn, , , adCmdTable
> ..Update
> ''.EditMode
> ''.Update
> ..Close
> End With
> '9999'
> I'm new to VBA.
> Tom
> > rsJob.Update
> > Kevin
> to
> to
> any
> > on
> > > Thank you
> > > Tom
I don't have the ADO 2.5 doc's available, so I'll use the 2.7. ADO
certainly does update tables, but can be a little quirky. A few things I
notice:
In the recordset Open method Options argument you have used a
CommandTypeEnum value of adCmdTable. That value is intended for use when
opening an entire table by name. To open the recordset using the SQL
string, change that argument to adCmdText, or just leave it out.
You cannot use an adOpenDynamic CursorType with a adUseClient
CursorLocation. From the doc's:
a.. Static cursor - provides a static copy of a set of records for you to
use to find data or generate reports; always allows bookmarks and therefore
allows all types of movement through the Recordset. Additions, changes, or
deletions by other users will not be visible. This is the only type of
cursor allowed when you open a client-side Recordset object.
Set a Watch on the recordset object, and check it after calling the Open
method to see what properties are actually being set.
If your strSQL indeed evaluates to
SELECT * FROM Hydrant WHERE Hydrant.HydrantId = '9999'
then the HydrantId column data type should be Text. If the data type is
numeric, get rid of the single quotes.
You do not need the first Update method call. EditMode is a property
intended to test whether the current record has been changed or a new record
has been added. You don't need it in the code below.
Check the actual value of the LockType property (in the Watch window) after
the recordset is open. If it is adLockBatchOptimistic then write the
recordset with the UpdateBatch method instead of the Update method.
Final note, when you attempt multi-table joined recordsets you must use a
formal Join clause in the Select statement to get an updateable recordset.
Check out the recordset Supports method when you want to find out if a
recordset operation is possible for a given provider.
John Goodfellow
irtfnm
use john at goodfellowassoc dot com
news:26300F275FFC704C5B2C613197605E8E@in.WebX.maYIadrTaRb...
> Kevin,
.Update
> message.
> With oRS
> .Update
> ''.EditMode
> ''.Update
> .Close
> End With
> '9999'
requested
> I'm new to VBA.
> Tom
> > rsJob.Update
> > Kevin
blocks
> to
trying
> to
> any
and
UPDATEs
> > on
> > > Thank you
> > > Tom
