Unable to set Paper Size through VBA
zhuanqiang.tan
zhuanqiang.tan
Please save me...
I'm trying to plot 60,000 dwgs to pdf, and when i use the default driver (DWG to PDF.pc3) and CanonicalMediaName to set the paper size to ANSI expand B (please see below) the plotter still defaulted to the ANSI full bleed paper size.
PtConfig.ConfigName = "DWG to PDF.pc3"
PtConfig.CanonicalMediaName = "ANSI_expand_B_(11.00_x_17.00_Inches)"
My internal AutoCAD expert showed me how to change the Plotter's default paper size, AND then in Options to "Use the plot device paper size". I rebooted AutoCAD and noted the settings DID change in AutoCAD, but somehow when i run the VBA code i'm still getting full bleed. Does anyone know why my options aren't taking effect? Thank you.
zhuanqiang.tan
Just an update for everyone. I was able to "workaround" this problem. Before i share the solution, i'd still appreciate anyone who can enlighten me on why i was not able to set the paper size via CanonicalMediaName. It's so annoying...
And here's the "workaround". i put quotes around "workaround" because what i ended up with is probably a better solution. i ended up saving a Page Setup with all the configurations i need, and then just having the code pick the setup. And voila, it works and i can leave work on time tonight.
Set PtConfigs = ACAD.ActiveDocument.PlotConfigurations
Set PtConfig = PtConfigs.Item("Winfab")
Ed__Jobe
If you have that many drawings to process, I highly recommend that you get Bluebeam Revu for CAD. It has a bactch processing tool that can override page setups.
Ed
How to post your code.
zhuanqiang.tan
Hi Ed, thanks for the feedback here. It's good to learn of a new tool. But do you by any chance know why i wasnt able to set up the paper size via VBA in the first place?
Ed__Jobe
You didn't show your code, but did you apply the settings to ActiveLayout? I only see that you created a PlotConfig. I don't know if it was used to plot with.
Ed
parkovaya1JX4QX
Community Visitor
Community Visitor
This will work. The trick is that the names are not equivalent!
NewLayout.GetLocaleMediaName(mediaNames(x)) <> mediaNames(x)
In this example, instead of "A1" I have the name like "user000"
So to set CanonicalMediaName="A1" you first need to find it by comparison
    Dim NewLayout As AcadLayout
    Dim mediaNames As Variant
    Set NewLayout = ThisDrawing.Layouts("Layout1")
    With NewLayout
        .ConfigName = "Default Windows System Printer.pc3"
        .RefreshPlotDeviceInfo
    End With
    ' List all the media names, and their localized version
    mediaNames = NewLayout.GetCanonicalMediaNames()
    For x = LBound(mediaNames) To UBound(mediaNames)
        'Debug.Print mediaNames(x)
        'Debug.Print NewLayout.GetLocaleMediaName(mediaNames(x))
        If NewLayout.GetLocaleMediaName(mediaNames(x)) = "A1" Then '!important
            MediaName = mediaNames(x)
            Exit For
        End if
    Next
    NewLayout.CanonicalMediaName = MediaName
