05:16 AM
Hi, I am not sure if anyone encounter this situation.
I have some codes to search for a particular block then print the attribute to excel. The problem I am faced with at the moment is that vba is not picking up the specified block but if I physically go in to the drawing and reset each block then vba will pick up those blocks. Does anyone have any idea to overcome this with out having to go into every drawing and resetting the blocks. Resetting the block is not an option because some of the blocks are dynamic blocks.
below is the code I am using to read to read the block.
Private Sub OpenFile(objfile As Object) Dim NewAcad As Boolean NewAcad = False Dim ACAD As AcadApplication 'Create ACAD variable of type AcadApplication On Error Resume Next 'This tells VBA to ignore errors Set ACAD = GetObject(, "AutoCad.Application") 'Get a running instance of the class AutoCAD. On Error GoTo 0 'This tells VBA to go back to NOT ignoring errors If ACAD Is Nothing Then 'Check to see if the above worked Set ACAD = New AcadApplication 'Set the ACAD variable to equal a new instance of AutoCAD NewAcad = True End If ACAD.Visible = True 'Once loaded, set AutoCAD to be visible Dim DWG As AcadDocument Dim releaseFile As String 'file name Set DWG = ACAD.Documents.Open(objfile) Dim FixError As Variant DWG.AuditInfo FixError ' audit and fix error in drawing DWG.PurgeAll ' purge drawing Dim blkName As String blkName = "TAG-PART" Dim blk As AcadBlockReference Dim blks As Variant Dim attrs As Variant Dim attr As Variant Dim i As Integer blks = FindBlocksOnAllLayouts(DWG, blkName) ' found all blks(i) = "TAG-PART" in layout If VarType(blks) = vbEmpty Then MsgBox "No block """ & blkName & """ found in current drawing!" Else For i = 0 To UBound(blks) Set blk = blks(i) ' each "TAG-PART" stored in array attrs = blk.GetAttributes() ' get attribure from blk For Each attr In attrs ' for each attr in the all the attrs in the block "TAG-PART" 'MsgBox attr.TagString & " = " & attr.TextString Cells(n + 1, 2) = attr.TagString Cells(n + 1, 3) = attr.TextString n = n + 1 ROW_FIRST = n + 1 Next Next End If DWG.Close True End Sub Function FindBlocksOnAllLayouts(DWG As AcadDocument, blkName As String) Dim blks() As AcadBlockReference Dim i As Integer Dim ent As AcadEntity Dim blk As AcadBlockReference Dim Layout As AcadLayout Set Layout = DWG.ModelSpace.Layout Dim lay As AcadLayout For Each ent In Layout.block ' each entity in the block If TypeOf ent Is AcadBlockReference Then Set blk = ent If UCase(blk.Name) = UCase(blkName) Then ' if blk.name is TAG-PART ReDim Preserve blks(i) Set blks(i) = blk i = i + 1 End If End If Next FindBlocksOnAllLayouts = blks ' found block TAG-PART End Function
