How to caliculate Rectangle Area with vba
i want to caliculate different shape areas and take that area into excel sheet which is in 3 columns Length ,Width and Area can any one make Lisp file or Excel Vba Program?
sieclaprzemyslaw
Hello! Below you can see simple code (just to start with something).I did one main assumption:
User will select rectangles only (4 vertex, lineweight closed polylines).
When you select all of those rectangles, macro will collect data and put into your clipboard.
You need only to paste it into excel file with space character as separator.
Sub rectangleExport()
Dim oSelection As AcadSelectionSet
On Error Resume Next
Set oSelection = ThisDrawing.SelectionSets.Add("rectangles")
If Err.Number <> 0 Then
ThisDrawing.SelectionSets.Item("rectangles").Clear
Set oSelection = ThisDrawing.SelectionSets.Item("rectangles")
oSelection.SelectOnScreen
Dim obJect As AcadObject
Dim oPol As AcadLWPolyline
Dim recArray() As String
Dim howMany As Integer
    howMany = 0
Dim tempLine As AcadLine
Dim xMeasure As Double
Dim yMeasure As Double
Dim tempPoint1(2) As Double
Dim tempPoint2(2) As Double
If oSelection.Count = 0 Then
MsgBox "Nothing was selected"
oSelection.Delete
Exit Sub
For Each obJect In oSelection
    If TypeOf obJect Is AcadLWPolyline Then
        Set oPol = obJect
        ReDim Preserve recArray(howMany)
        recArray(howMany) = oPol.Area
        tempPoint1(0) = oPol.Coordinates(0): tempPoint1(1) = oPol.Coordinates(1): tempPoint1(2) = 0#
        tempPoint2(0) = oPol.Coordinates(2): tempPoint2(1) = oPol.Coordinates(3): tempPoint2(2) = 0#
        Set tempLine = ThisDrawing.ModelSpace.AddLine(tempPoint1, tempPoint2)
        xMeasure = tempLine.Length
        recArray(howMany) = recArray(howMany) & " " & xMeasure
        tempLine.Delete
        tempPoint2(0) = oPol.Coordinates(6): tempPoint2(1) = oPol.Coordinates(7): tempPoint2(2) = 0#
        yMeasure = tempLine.Length
        recArray(howMany) = recArray(howMany) & " " & yMeasure
        tempLine.Delete
        howMany = howMany + 1
Next
Dim a As Integer
Dim mSg As String
mSg = "Area Width Length" & vbNewLine
For a = 0 To howMany - 1
mSg = mSg & recArray(a) & vbNewLine
Next a
Dim clipboard As MSForms.DataObject
Set clipboard = New MSForms.DataObject
clipboard.SetText mSg
clipboard.PutInClipboard
MsgBox howMany & " rectangles were found. Data is avaiable in your clipboard."
End Sub
