Ucase??
Ucase??
Message 1 of 10
Ucase??
I have a little program that runs fine for me, but two other
people have tried it and it hangs on this line
COLUMN.Name = UCase(COLUMN.Name)
They say it is highlighting the Ucase when it hangs. Ucase
appears to be a standard VBA function so does anyone have any
ideas why it might hang for some and not others on this?
Kent Keller
Check out the Mechanical Desktop FAQ @
http://webhome.idirect.com/~dfulford/
Replies (9)
Message 2 of 10
I'm not sure but ucase returns a variant and ucase$ returns a string.
Could it be that COLUMN.Name only accepts strings?
Stuart Nathan @
http://www.office-manager.co.uk
Message 3 of 10
Kent,
Instead of using
use this
COLUMN.Name =VBA>.UCase(COLUMN.Name)
Message 4 of 10
Hi
Is the > a typo?? when I add it I get a invalid or unqualified reference.
What does the VBA do, I can't find anything in the help explaining it.
Unfortunately the program runs fine for me, and the people that it doesn't
work for aren't real quick about trying things so I don't yet know if this
fixed it or not.
Kent Keller
Strobe Data Inc.
www.strobedata.com
If only women came with pull-down menus and on-line help.
"MASMITH" wrote in message
news:eefe23e.1@WebX.SaUCah8kaAW...
> Kent,
> Instead of using
> use this
Message 5 of 10
Hiya,
Is the COLUMN object a control on a userform? If so... check the users machine to make sure the control is actually present.
I have found that on some machines, a control can get corrupted and if its not present, you will get similar errors in standard VBA functions.
Hope this helps!
Micah
Message 6 of 10
Sorry Micah for the email, wrong button again!!!
Hi
No it isn't a user form control, it is a Mechanical Desktop part list column
definition.
Dim COLUMN As McadColumnDefinition
I wish I could get it to fail on my machine so I could try a couple of
things. Anybody running MDT and want to do a couple of quick tests on it??
Kent Keller
Strobe Data Inc.
www.strobedata.com
"mnerren" wrote in message
news:eefe23e.3@WebX.SaUCah8kaAW...
> Hiya,
> Hope this helps!
> Micah
Message 7 of 10
what runtime error do you generate when it hangs?
-phix
Kent Keller wrote in message
news:eefe23e.-1@WebX.SaUCah8kaAW...
> Kent Keller
Message 8 of 10
Hi phix
they say it says
Compile error: Can't find project or library. (as displayed in
dialogue box)
The VBA debugger screen displays and highlights "UCase" in the
following line in the program:
Kent Keller
"Phix" wrote in message
news:eefe23e.5@WebX.SaUCah8kaAW...
> -phix
> > Kent Keller
Message 9 of 10
Hi Kent,
If thats the message they are getting then it is definitely a missing type library. Is that reference to the COLUMN object the first reference the code hits to an MCad object?
This has nothing to do with UCase I would say. Try the things I mentioned in my email, that should work.
Micah
Message 10 of 10
news:eefe23e.7@WebX.SaUCah8kaAW...
> Hi Kent,
No it is closer to the end of the code than the begining. There are lots of
other calls to the MCad objects before it.
I am hoping to get someone to try it tonight. Thanks for all your help.
> Micah
Kent Keller
Strobe Data Inc.
www.strobedata.com
The horn of plenty is usually the one behind you in traffic!
