Tutorial for VBA developers to use Visual Basic and C# 2008 Express Edition
Message 1 of 13
Hi All,
I am attaching two documents that provide an introductory quick start tutorial on using the VB and C# 2008 express edition for Acad development. The target audiance is VBA developers contemplating migration of their VBA code to the .NET environment. This tutorial does not talk about how to use the AutoCAD based APIs. It just gives a very quick introduction on how to create a very simple .NET application loadable into AutoCAD using the VB and C# Express Edition.
Your comments are most welcome.
Gopinath
Replies (12)
Message 2 of 13
Talk about Karma! I just installed VS08 yesterday. After fumbling around in the IDE, I decided to fumble around online to try and find some documentation that would keep me from fumbling. Thanx!
Message 3 of 13
Thank you Gopinath, for sharing...
Cheers
Filipe Francisco
Message 4 of 13
Thanks gopinatht for taking the time to put this together.
The tutorial shows use with autocad 2010, what version of autocad can you begin using VS 2008 Express?
Cadger
Message 5 of 13
Can't tell you much because I can't open it.
Consider distributing in a format that more people have access to.
On my WinXP system, 'docx' is an unknown file type.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:6129150@discussion.autodesk.com...
Hi All, I am attaching two documents that provide an introductory quick
the VB and C# Express Edition. Your comments are most welcome. Thanks
Gopinath
Message 6 of 13
to open docx (is a format of Office 2007) you need a converser to open that file
Microsoft Office Compatibility Pack for 2007 Office Word, Excel and PowerPoint File Formats
http://www.microsoft.com/downloads/details.aspx?FamilyId=941B3470-3AE9-4AEE-8F43-C6BB74CD1466&displaylang=en
Cheers
Filipe Francisco
Message 7 of 13
PDF C# version
Message 8 of 13
PDF VB version
Message 9 of 13
I have Office on another system (slows down my development
system way too much), and was able to open it there.
wrote in message news:6129385@discussion.autodesk.com...
file Microsoft Office Compatibility Pack for 2007 Office Word, Excel and
Cheers Filipe Francisco
Message 10 of 13
Thanks Cadger for converting the docs to PDF. Also here is the doc version of the documents for those who have older version of MS Office.
Message 11 of 13
Yes, I tested Express against the upcoming release Acad 2010 but the .NET environment being what it is, it should be possible to use it with previous versions of Acad as well like acad 2009, 2008 or 2007. Just remember to use the right version of acmgd.dll and acdbmgd.dll with these versions of autocad.
Please do let me know if you face any problems doing this.
Message 12 of 13
You should also make clear that they should use the
assemblies that ship with the ObjectARX SDK, rather
than the ones in the AutoCAD root folder (they are not
the same, and using the latter can lead to WSODs in
Visual Studio, depending on what one is doing).
wrote in message news:6130004@discussion.autodesk.com...
autocad. Please do let me know if you face any problems doing this.
Message 13 of 13
Good point. However, the down side of recommending the OARX SDK assemblies is that I am assuming the developers downloaded and installed the right version of SDK. In fact, in my experience, I have found customers face unresolved assembly errors more with the sdk rather than acad install. This is because, it is more likely that users install acad at default location then the arx sdk. Another reason I did not emphasise the SDK was that it is not necessary for customers to install the SDK to do pure Acad .NET programming (though installing the SDK helps a great deal with samples and documentation). Finally, I wanted to keep the tutorial document as simple and clutter free as possible so that inexperienced programmers can get up and running as quickly as possible.
I guess there is no way to win here. As the next step to the the tutorial doc, I am planning to create a project template the developers can install on VB and C# express and use that to create skeletal AutoCAD .NET projects. The problem here too is the assumption of the location of the references.
However, I am interested in a typical scenario where you see the White Screen of Death. Can you think of a common scenario with the the acad assemblies? Or are you talking about unresolved assemblies too because of install into non-default path?
